Aquila Development Board
(Double-Click to Zoom)
Getting Started
This section contains initial information needed to set-up the Aquila Development Board for the first time.
Recommendation for the first-time order
Getting started
The Aquila SoMs come with Toradex Easy Installer pre-installed. Once you power-on the board, it will display a list of available images to be installed. Check out how to get started with the Toradex Easy Installer:
For detailed instructions on how to start developing your software for this system on module, check out our software page. The following Linux-based offerings have support coming soon:
We have quick video tutorials:
Having trouble?
Please contact our technical support. Various option of technical support are mentioned below:
Hardware Features
Check the hardware features on the product page in toradex.com:
Block Diagram
Datasheets
Coming soon:
Design Resources
Aquila Development Board Design Data V1.2
Design and Layout Guide
Layout Design Guide
Compatible Products
Revision History
Product Number (PID8) Format
Product Numbering Scheme
FieldDescription
Example
0029: Apalis iMX6D 512MB
00: Assembly Variant A
PN: 0177
Product #Product DescriptionChanges from Previous VersionRelease DateRelated Documents
01771200
Aquila Development Board V1.2A
Initial Release
Q3 2024
Initial release, no PCN document
01771201
Aquila Development Board V1.2B
- Fix on USB1 enable signal: Change assembly status of R399 from “Not Assembled” to “Assembled”, Change assembly status of R408 from “Assembled” to “Not Assembled”
- Fix to reduce power button delay: Change assembly status of C47 from “assembled” to “Not Assembled”
Q4 2024
Errata/Known Issues
Errata Document
Aquila Development Board Errata Document
Errata/Known issues
None
