Building External Kernel Modules With Torizon
It is often necessary to add a kernel module to a Torizon OS image. There are two possibilities:
- Add a kernel module that is available in the kernel source, or in-tree. In this case, please make a request in our community. If you tell us the exact kernel config that must be enabled and it does not have a negative impact on Torizon OS, we'll add it as a module.
To check whether a given kernel config is already enabled, you can simply check the kernel config of a module running Torizon OS (zcat /proc/config.gz) or you can search for the configuration on the toradex-kernel-cache repository, which stores the kernel config for official Torizon OS images. When searching in the repository, be sure to choose the correct branch for your Torizon OS version.
- Add an out-of-tree kernel module, in other words, a module that is external to the Linux kernel source tree. In this article, you will learn how to do it.
Some examples where this is necessary:
- When adding support to some device/peripheral you're using.
- When including some proprietary code.
You'll need to compile the kernel module's source code against the kernel source to make it compatible.
The typical way to do this in embedded Linux would be to add your kernel module via the Yocto Project/OpenEmbedded build system. However, this requires quite a bit of knowledge, and as we deliver Torizon OS as a binary distribution, we try to simplify this process greatly in a way that you don't need to fall back to a Yocto build.
Pre-requisites
The pre-requisite to complete these instructions are:
- Prerequisites from Configure Build Environment for Torizon Containers installed.
- A Toradex SoM with Torizon installed.
- Having read the Torizoncore Builder - Getting Started article can be helpful.
- A Torizon OS image downloaded.
- Source code for whatever kernel module you want to build. We will provide an example code in the exercise below.
Hello World Kernel Module Example
Begin by organizing your kernel module source code into a single directory; let's call this your hello-mod. At a minimum, your source code should have at least one source C file and one Makefile.
To get the kernel module example, called hello-mod, from our Github repository, run the command below:
$ git clone https://github.com/toradex/hello-mod
Ihe files below are the source C file and the Makefile, respectively, contained in this hello-mod example:
#include <linux/module.h>
int init_module(void)
printk("Hello World!\n");
return 0;
void cleanup_module(void)
printk("Goodbye Cruel World!\n");
MODULE_LICENSE("GPL");
Take extra notice of the Makefile. In particular, notice the environment variable $(KERNEL_SRC). The TorizonCore Builder tool uses this variable, so include this in your Makefile as shown below. Alternatively, you can also use $(KDIR) instead. You do not need to define both these variables, but including at least one is mandatory.
obj-m := hello.o
SRC := $(shell pwd)
all:
$(MAKE) -C $(KERNEL_SRC) M=$(SRC) modules
clean:
$(MAKE) -C $(KERNEL_SRC) M=$(SRC) clean
Development and Production: Add External Kernel Modules with TorizonCore Builder
Applying an External Kernel Module to a Custom Image
Approach 1: Applying an External Kernel Module to a Custom Image Using the Build Command
TorizonCore Builder build command generates a custom Torizon OS image with the external kernel module built, ready to be installed with Toradex Easy Installer, named torizon-core-docker-colibri-imx6-Tezi_5.3.0.CUSTOM in the example below. This is achieved using a configuration YAML file, tcbuild.yaml as default.
It requires a Toradex Easy Installer image of Torizon OS (preferably without containers), torizon-core-docker-colibri-imx6-Tezi_5.3.0+build.7.tar in this case, as input. The directory with the kernel module source code is passed as customization: kernel: modules: source-dir.
# Sample configuration file:
input:
easy-installer:
# Sample customization: build hello-mod module into the image
customization:
kernel:
modules:
- source-dir: hello-mod/
autoload: no
output:
easy-installer:
Notice the kernel: modules: autoload parameter of the hello-mod kernel module defined to no. This means that the kernel module will not be automatically loaded on boot time. To enable loading on boot time just change this parameter to yes.
The directory with the kernel module source code hello-mod should be available before running the build command.
Build The Custom Image
$ torizoncore-builder build
Pulling done.
Deploying done.
Packing rootfs...
Packing rootfs done.
- Using Toradex Easy Installer, the recommended method for production programming.
- Directly on the board through SSH, the recommended method during development.
- Through Torizon Cloud server, the recommended method to perform updates on a device already deployed to the field.
- It's also possible to use a static-delta approach, which is more network efficient.
Directly, through SSH
Torizon Cloud
Approach 2: Applying an External Kernel Module to a Custom Image Using Standalone Commands
In this second approach, instead of using a configuration YAML file and a one-step command, the generation of the custom Torizon OS with the external kernel modules is done using standalone commands, each performing one step towards this generation.
This approach is especially useful when making incremental changes, generating multiple images with different external kernel modules (or other customizations like different device tree overlays). As you will see, including an external kernel module on an image of Torizon OS that has other customizations (including other external kernel modules) is just a matter of performing the apply, merge and deploy stages. If you want to remove one or more kernel modules, it is also necessary to come back to the initial image of Torizon OS by executing the images unpack command again.
To generate a custom Toradex Easy Installer image with the desired external kernel modules follow the sequence of steps below.
Unpack an Input Image
You just need to execute this again if you want to remove one or more kernel modules that you have applied before to the image. Then, you are ready to apply multiple changes to the image. For example, in addition to applying external kernel modules, you can also apply a custom splash screen, a new device tree, among other possibilities.
Build a Kernel Module
To build a kernel module from a directory with the kernel source code, hello-mod in this case, run the command kernel build_module below. After some time, if the compilation was successful, you'll see output similar to the following:
$ torizoncore-builder kernel build_module hello-mod
make: Entering directory '/workdir/hello-mod'
make -C /storage/linux M=/workdir/hello-mod
make[1]: Entering directory '/storage/linux'
AR /workdir/hello-mod/built-in.a
CC [M] /workdir/hello-mod/hello.o
Building modules, stage 2.
MODPOST 1 modules
CC [M] /workdir/hello-mod/hello.mod.o
LD [M] /workdir/hello-mod/hello.ko
make[1]: Leaving directory '/storage/linux'
make: Leaving directory '/workdir/hello-mod'
Kernel module(s) successfully built and ready to deploy.
All kernel module(s) have been built and prepared.
It is important to notice that the example directory with the kernel module source code named hello-mod builds a module named hello, as it can be seen in the line below, taken from the output of the kernel build_module command:
If you're building from two or more different sets of source code, you can run kernel build_module multiple times targeting each source directory separately. Each kernel module will be added in succession.
If you want a kernel module to load on boot, you should pass the argument --autoload to the kernel build_module command.
For more details about the kernel build_module command, please check the kernel build_module command in the commands manual.
Merge Changes
Merge the external kernel modules (as well as other customizations like a splash screen or a new device tree) into the base Toradex Easy Installer image of Torizon OS - use whatever branch name you want.
$ torizoncore-builder union --union-branch=custom-branch
Verifying The New Custom Image On The Device
# sudo ostree admin status
Password:
- The one in the output of the
unioncommand in the case of the standalone commands - The one in the "Deploying OSTree with checksum ..." part of the output of the
buildcommand.
Load The External Kernel Module
After deploying the image, you should be able to use the modprobe command on the board to load your kernel module. As a note, by default, the kernel module will not load on boot. If you are using the interactive approach, you can change this behavior by adding the --autoload argument to the build_module command. If you are using the build command approach, you can set the autoload parameter to yes in the configuration file.
To load your kernel module, run the command below. It is important to notice that the example directory with the kernel module source code named hello-mod builds a module named hello, therefore we should enable a module named hello and not hello-mod.
# sudo modprobe hello
Differently from defining the kernel module to autoload on TorizonCore Builder, every time you reboot the device you should execute the modprobe command to load the kernel module.
Check The External Kernel Module
After deploying the image and loading the kernel module, you should be able to see your kernel module in the loaded kernel modules list. To do it, you can use the command below:
# lsmod
Module Size Used by
joydev 20480 0
stmpe_adc 16384 0
industrialio 65536 1 stmpe_adc
imx_sdma 28672 2
virt_dma 16384 1 imx_sdma
coda_vpu 73728 0
imx_vdoa 16384 1 coda_vpu
videobuf2_vmalloc 16384 1 coda_vpu
uio_pdrv_genirq 16384 0
uio 16384 1 uio_pdrv_genirq
hello 16384 0
openvswitch 110592 0
nsh 16384 1 openvswitch
nf_conncount 16384 1 openvswitch
nf_nat 36864 1 openvswitch
libcomposite 53248 0
