Temperature Sensor (Linux)
The SoCs often have one or more internal temperature sensors. From Linux userspace, it is possible to read the temperature values on /sys.
To better understand how things work on NXP i.MX SoCs, one can read section 2.7 - Thermal of the i.MX Reference Manual
NXP/Freescale i.MX 6 Based Modules​
The i.MX 6 provides a temperature reading of the SoC's internal temperature plus the board temperature is available via ADC/touch chip albeit with much worse accuracy. The output is in millidegrees Celsius aka 1000ths of degrees Celsius. Therefore it must be divided by 1000 to obtain regular degrees.
root@colibri-imx6:~# cat /sys/devices/virtual/thermal/thermal_zone0/temp
54325
root@colibri-imx6:~# cat /sys/bus/iio/devices/iio\:device0/in_temp8_input
35318
NXP/Freescale i.MX 6ULL and i.MX 7 based modules​
Both i.MX 6ULL and i.MX 7 based modules have an integrated sensor for monitoring the temperature of the CPU. The output is in millidegrees Celsius aka 1000ths of degrees Celsius. Therefore it must be divided by 1000 to obtain regular degrees.
root@colibri-imx6ull:~# cat /sys/devices/virtual/thermal/thermal_zone0/temp
57140
NXP/Freescale i.MX 8/8X Based Modules​
On i.MX 8/8X, power management and temperature monitoring are entirely handled by the SCFW.
The internal temperature sensors of i.MX 8QuadMax/8QuadPlus and i.MX 8QuadXPlus/8DualX are split into zones, accessible through /sys/devices/virtual/thermal/thermal_zoneX:
apalis-imx8-06543292:~$ ls /sys/devices/virtual/thermal/
cooling_device0 cooling_device1 cooling_device2 cooling_device3 cooling_device4 cooling_device5 cooling_device6 cooling_device7 cooling_device8 thermal_zone0 thermal_zone1 thermal_zone2 thermal_zone3 thermal_zone4 thermal_zone5
You can read the temperature from a thermal zone as follows:
apalis-imx8-06543292:~$ cat /sys/devices/virtual/thermal/thermal_zone0/temp
33800
The zones are described as follows for i.MX 8:
  • zone 0 represents the temperature of the A53 CPU cores.
  • zone 1 represents the temperature of the A72 CPU cores.
  • zone 2 represents the temperature from one of the GPUs.
  • zone 3 represents the temperature from the other GPU.
  • zone 4 represents the temperature for the PMIC (Power management integrated circuit).
  • zone 5 just defaults to 70 degrees Celsius as nothing is assigned there.
And for i.MX 8X:
  • zone 0 represents the temperature of the A35 CPU cores.
  • zone 1 just defaults to 70 degrees Celsius as nothing is assigned there.
NXP/Freescale i.MX 8M Mini/8M Plus Based Modules​
The internal temperature sensors of i.MX 8M Mini Quad/DualLite and i.MX 8M Plus Quad/QuadLite are split into zones, accessible through /sys/devices/virtual/thermal/thermal_zoneX:
verdin-imx8mp-06817296:~$ ls /sys/devices/virtual/thermal/
cooling_device0 cooling_device1 cooling_device2 thermal_zone0 thermal_zone1
verdin-imx8mp-06817296:~$ cat /sys/devices/virtual/thermal/thermal_zone0/temp
28000
The zones are described as follows for i.MX 8M Mini:
And for i.MX 8M Plus:
  • zone 1 represents the temperature of the SoC near the ANAMIX.
NVIDIA Tegra 2 and 3 based modules​
The temperature sensor is able to report the PCB's temperature as temp1 and the NVIDIA Tegra T20/T30 chip's internal temperature as temp2. The output is provided in millidegrees Celsius aka 1000ths of degrees Celsius (Colibri T20 V1.x BSPs provided it in degrees Celsius). Therefore it must be divided by 1000 to obtain regular degrees.
root@colibri_t20:~# cat /sys/bus/i2c/devices/4-004c/temp1_input
29625
root@colibri_t20:~# cat /sys/bus/i2c/devices/4-004c/temp2_input
31125
root@colibri-t30:~# cat /sys/bus/i2c/devices/4-004c/temp1_input
52468
root@colibri-t30:~# cat /sys/bus/i2c/devices/4-004c/temp2_input
45625
NVIDIA Tegra K1 based modules​
The Apalis TK1 module comes with 2 temperature sensors, one which measures the temperature of the CPU die and another on the Apalis PCB. To read these temperatures, the hwmon subsystem is consulted. The output is provided in millidegrees Celsius aka 1000ths of degrees Celsius. Therefore it must be divided by 1000 to obtain regular degrees.
watch cat /sys/class/hwmon/hwmon?/temp1_input
Every 2.0s: cat /sys/class/hwmon/hwmon0/temp1_input /sys/class/hwmon/hwmon1/temp1_input /sys/class/hwmon/hwmo... apalis-tk1: Thu Mar 8 13:45:59 2018
47500
49500
45000
46500
35000
46000
To verify where temperatures are being measured
root@apalis-tk1:~# cat /sys/class/hwmon/hwmon?/name
CPU-therm
GPU-therm
MEM-therm
PLL-therm
Tboard_tegra
Tdiode_tegra
The last two refer to the sensors previously mentioned.
NXP/Freescale Vybrid based modules​
The Vybrid's internal temperature sensor is connected internally to its ADC module's analogue input channel, the readout of temperature is given by in_temp_input. The output is in millidegrees Celsius aka 1000ths of degrees Celsius. Therefore it must be divided by 1000 to obtain regular degrees.
root@colibri-vf:~# cat /sys/bus/iio/devices/iio:device1/in_temp_input
40760
