Version: Torizon OS 7.x.y
Capturing Changes in the Configuration of a Board on Torizon OS
During the development process with Torizon OS, usually it is required to capture configuration changes on the /etc directory that needs to be committed to the Torizon OS image.
Here are some examples of procedures that require changes in the configuration of the system:
This article shows how to capture these system configurations.
Pre-requisites
The pre-requisite to complete these instructions are:
  1. Download the setup script into some writable directory in your system (here we use ~/tcbdir/):
    $ mkdir -p ~/tcbdir/ && cd ~/tcbdir/
    $ wget https://raw.githubusercontent.com/toradex/tcb-env-setup/master/tcb-env-setup.sh
    note
    If you did this before then you can skip this step unless you want to update the setup script. When you source the script (next step) it will show you a warning message if it determines an update is advisable.
  2. Source the script:
    $ cd ~/tcbdir/
    $ source tcb-env-setup.sh
    Make sure to do this from every shell instance that you intend to use with TorizonCore Builder. For advanced usage, run source tcb-env-setup.sh -h, or see the project README. The latter has information about using the early-access version of the tool for those interested.
    tip
    • Remember to source the setup script every time you start a new terminal (or shell instance).
    • The setup script installs a Bash completion script for TorizonCore Builder, making it possible to autocomplete commands and parameters by just pressing the TAB key.
  3. Verify that the command torizoncore-builder is available:
    $ torizoncore-builder --help
If you have made any configuration changes, they will be saved in the /etc directory of your board. The isolate command will fetch all those changes (modifications, addition, deletion, and files and directories permissions and ownership). It requires an SSH connection for the communication between the host PC and the target board.
Get configuration changes from the target board, saving them in a specific directory, in this case changes1, with this command:
$ torizoncore-builder isolate --remote-host 192.168.1.117 --remote-username torizon --remote-password torizon --changes-directory changes1
Changes in /etc successfully isolated.
tip
tip
In order to keep credentials (files and directories permissions and ownership) the isolate command will create the file /etc/.tcattr which will be automatically used later by the union command.
For more details about the isolate command, please check the isolate command in the commands manual.
Applying Captured Changes to a Custom Image
Approach 1: Applying Changes to a Custom Image Using the Build Command
TorizonCore Builder build command generates a custom Torizon OS image with the captured configuration changes, ready to be installed with Toradex Easy Installer, named torizon-core-docker-colibri-imx6-Tezi_5.3.0.CUSTOM in the example below. This is achieved using a configuration YAML file, tcbuild.yaml as default.
It requires a Toradex Easy Installer image of Torizon OS (preferably without containers), torizon-core-docker-colibri-imx6-Tezi_5.3.0+build.7.tar in this case, as input. The directory (or directories) with the captured configuration changes is passed as customization: filesystem.
tcbuild.yaml
# Sample configuration file:
input:
easy-installer:
#Sample customization: insert the configuration changes made in the device
customization:
filesystem:
- changes1/
output:
easy-installer:
Build The Custom Image
$ torizoncore-builder build
Pulling done.
Deploying done.
Packing rootfs...
Packing rootfs done.
  • Through Torizon Cloud server, the recommended method to perform updates on a device already deployed to the field.
Directly, through SSH
tip
caution
Torizon Cloud
caution
Approach 2: Applying Changes to a Custom Image: Using Standalone Commands
In this second approach, instead of using a configuration YAML file and a one-step command, the generation of the custom Torizon OS with the captured configuration changes is done using standalone commands, each performing one step towards this generation.
This approach is especially useful when making incremental changes, generating multiple images with captured configuration changes (or other customizations like different device tree overlays). Including a directory with captured changes on an image of Torizon OS is just a matter of passing it as a --changes-directory argument to the union command. Therefore, it is just necessary to perform the union and deploy stages (also the isolate step is necessary if you want to capture the new configuration changes from the device).
To generate a custom Toradex Easy Installer image with the desired directories with captured configuration changes follow the sequence of steps below.
You just need to execute once. Then, you are ready to apply multiple changes to the image. For example, in addition to applying configuration changes captured from the device, you can also apply a custom splash screen, a new device tree, among other possibilities.
Merge Changes
As a reminder, you must have captured changes as explained previously.
Merge the captured configuration changes (as well as other customizations like a kernel module or a device tree) into the base Toradex Easy Installer image of Torizon OS - use whatever branch name you want.
caution
tip
caution
caution
Verifying The New Custom Image On The Device
# sudo ostree admin status
Password:
