Apalis iMX8 New Configurations
Effective 2024, NXP announced changes to the processor used in our current product offerings on the Apalis iMX8 system-on-modules, designating the parts as NRND (Not Recommended for New Designs).
The NRND designation occurred due to NXP releasing new versions of the automotive SoC with derated A72 and GPU frequencies, same as of the Industrial variants. For more details, check errata #6 from the Apalis iMX8 SoM Errata.
In response to that, we would like to inform you that Toradex will launch new product configurations featuring the Industrial qualified parts.
How Does This Impact You ?
The recommendation for existing Apalis iMX8 customers is to:
  • Test and move your product to the new configuration, with the Industrial SoC
With this change, you (1) mitigate possible functional failures on the automotive SoC, you (2) get an industrial-qualified chip – meaning it can operate for longer times, with an increased lifespan, and you (3) get a slightly lower cost SoM overall. There is no expected effort in migrating to the new Apalis iMX8, they are Hardware and Software compatible.
If you cannot switch to the new configuration, the existing configurations of the Apalis iMX8, which use the NRND automotive-qualified parts, will be available and support will continue for as long as the longevity commitment of the processor. To keep using this configuration you can either:
  • Derate Cortex-A72 and GPU frequencies to mitigate possible functional failures, as these failures are seen to be connected with high resource demand on this SoC
    How to derate
    We provide a patch implementation for derating. You can use it as reference and adapt to your use-case. Use our Community in case you need help.
  • Keep the clocks as they currently are, and thoroughly test your application in high demanding scenarios
Samples of the new product configurations are expected to be available in Q1/2025. We will continue to keep you informed with updates on availability and technical details as we approach the release date.
The table below presents the new configurations with the Industrial SoC, relative to the existing configurations:
Existing configurations with Automotive SoCNew Configurations with Industrial SoC
0037 - Apalis iMX8QM 4GB WB IT0091 - Apalis iMX8QM 4GB WB IT
0047 - Apalis iMX8QM 4GB IT0092 - Apalis iMX8QM 4GB IT
0048 - Apalis iMX8QP 2GB WB0093 - Apalis iMX8QP 2GB WB
0049 - Apalis iMX8QP 2GB0094 - Apalis iMX8QP 2GB
0067 - Apalis iMX8QM 8GB WB IT0095 - Apalis iMX8QM 8GB WB IT
We are working hard to maintain the high standards our customers expect. Our team has worked diligently to ensure the new products are not only aligned with current market needs but also future-proofed for long-term success.
Stay tuned for more information, and thank you for your continued support.
