Version: Torizon OS 7.x.y
Setting up Displays with Torizon
During the development cycle of a product with a GUI, you usually go through 3 phases when it comes to displays:
Evaluation: often, you will do a basic evaluation using a regular monitor over VGA/DVI-D/HDMI - or similar interfaces, if available. We provide an out-of-the-box experience, where you plug in the monitor and power-on the hardware.
Proof of Concept/Prototype: even with the advantages of cross-development tools and IDEs enabling a good experience for developing GUIs in a development computer, it is often common to make tests on the real end device. We sell touch screen displays that either deliver an out-of-the-box experience or a relatively easy configuration.
Development and Production: often, you want or need a custom display in your final product. The reasons are various: price, robustness, brightness, size, interface, EMI compliance, among others. Supporting a custom display is not an easy task for a beginner, mainly if you use a display with insufficient documentation and Linux support. We document how to enable a custom display, but you must expect that some effort is associated with the process.
Toradex tests and recommends using the following displays with its Computer on Modules (CoM) during early phases of development:
It is often necessary to modify the Linux Device Tree to integrate a display to the board and configure its pin and timing settings. Device Tree Overlays provide a way to alter the overall device tree without the need for re-compiling the complete Device Tree.
For the display listed previously, Toradex provides an easy way to set-up and get it running with ready-to-use device tree overlays. It also means that you can tweak the existing overlays to support other displays as well. This article lists the available Device Tree Overlays provided by Toradex and how to enable it on Torizon OS.
Using a Monitor​
All computer on modules have a default display interface enabled by default. Unless explicitly stated otherwise, the following interfaces are enabled by default:
  • Colibri Family: RGB interface, commonly connected to VGA, DVI-A, or the Unified Display Interface on our carrier boards.
  • Apalis Family: HDMI interface, commonly connected to a DVI-D or the standard HDMI connector on our carrier boards.
    • You can use an HDMI or DVI monitor, depending on the carrier board you are using.
  • Verdin Family: MIPI DSI interface, commonly exposed on a board-to-board connector that can receive multiple display adapters, as our Toradex DSI to HDMI Adapter which is enabled by default, the Toradex DSI to LVDS Adapter which would require additional configuration, or the Toradex DSI Display Adapter which would require additional configuration.
    • You can use an HDMI monitor, through the Toradex DSI to HDMI adapter.
  • Aquila Family: a MIPI DSI interface enabled by default. Display Port might be available depending on SoC used in the Aquila module.
Learn more by checking the pre-enabled Device Tree Overlays
Configure Toradex Displays​
You must apply some device tree overlays to make a specific display work. We already provide all overlays for the displays from our webshop, you just have to:
After you enable the display, check the section at the end of this article on how to test the display and touch.
Find the Correspondent Device Tree Overlays​
See below the list of available Display Device Tree Overlays provided by Toradex:
Displays​
Default resolution with these overlays: 1920x1080
Native Interface:
ModuleStarting from versionOverlay
Verdin iMX8M Plus6.1.0verdin-imx8mp_hdmi_overlay.dtbo
Apalis iMX8 QuadMax6.1.0apalis-imx8_hdmi_overlay.dtbo
Apalis iMX8 QuadPlus6.1.0apalis-imx8_hdmi_overlay.dtbo
Apalis iMX66.0.0apalis-imx6_hdmi_overlay.dtbo
Colibri iMX66.0.0colibri-imx6_hdmi_overlay.dtbo
Using Toradex DSI to HDMI adapter:
Verdin iMX957.3.0verdin-imx95_dsi-to-hdmi_overlay.dtbo
Verdin iMX8M Plus6.1.0verdin-imx8mp_dsi-to-hdmi_overlay.dtbo
Verdin iMX8M Mini6.1.0verdin-imx8mm_dsi-to-hdmi_overlay.dtbo
Verdin AM626.4.0verdin-am62_dsi-to-hdmi_overlay.dtbo
Verdin AM62P7.3.0verdin-am62p_dsi-to-hdmi_overlay.dtbo
Aquila AM69/TDA47.1.0aquila-am69_dsi-to-hdmi_overlay.dtbo
Aquila iMX957.5.0aquila-imx95_dsi-to-hdmi_overlay.dtbo
Lino iMX937.6.0lino-imx93_dsi-to-hdmi_overlay.dtbo
| SMARC iMX8M Plus | 7.3.0 | toradex-smarc-imx8mp_dsi-to-hdmi_overlay.dtbo | | SMARC iMX95¹ | 7.3.0 | toradex-smarc-imx95_dsi-to-hdmi_overlay.dtbo | | OSM iMX93 | 7.6.0 | toradex-osm-imx93_dsi-to-hdmi_overlay.dtbo |
¹ Requires customized SoM mount. Contact us for further information.
Using Colibri DSI to HDMI adapter:
Colibri iMX8X6.2.0colibri-imx8x_dsihdmi_overlay.dtbo
Enable and Deploy Device Tree Overlays​
For instructions about how to enable the overlays, see the Device Tree Overlays on Torizon article.
Configure Other Displays with Torizon​
We recommend using the device tree overlay to support a specific display to specify the exact display resolution and timings. We recommend looking at the Device Trees on Toradex System on Modules article for sample implementations and modify them according to your display resolution and timings. For more information on usage for overlays, check the instructions in the previous section.
Remember to check your display's datasheet. Every manufacturer provides display timings in a slightly different way.
The Horizontal period must be the sum of hback_porch + hactive + hfront_porch + hsync-len and the Vertical period must be the sum of vback_porch + vactive + vfront_porch + vsync-len. Hsync-len and vsync-len parameters are not allowed to be zero sometimes.
Check our examples for a starting point. Copy the most appropriate in the test.DTS you have created in a previous step:
LVDS display example: Capacitive Touch Display 10.1" LVDS Overlay
DSI display example: Capacitive Touch Display 10.1" DSI Overlay
Parallel RGB display example: Capacitive Touch Display 7" Parallel Overlay
Other examples: Toradex Device Tree Overlays on GitHub
To deploy your customized Device Tree Overlay, check the instructions in the previous section. After you enable the display, check the section at the end of this article on how to test the display and touch.
Splash Screen Limitation with TorizonCore Builder​
Toradex-supported displays ship as built-in kernel drivers, flagged =y in the kernel configuration, menuconfig. Built-in drivers initialize early in the boot sequence, before init runs, so the splash screen renders as soon as the framebuffer is available.
When you use TorizonCore Builder to add a third-party or custom display driver, as described in Building External Kernel Modules With Torizon, the driver is built as a loadable kernel module, flagged =m, instead. Loadable kernel modules are loaded by udev or modprobe during userspace init, which happens significantly later in the boot sequence. As a result, the framebuffer only becomes available after userspace init starts, and the splash screen does not appear at boot.
Setup the Splash Screen with a Custom Display Driver​
To setup the splash screen, embed the display driver, and its dependencies into the initramfs. Drivers included in the initramfs load during early userspace, before the root filesystem mounts, making the framebuffer available early enough again for the splash screen to render.
TorizonCore Builder cannot embed kernel modules into the initramfs. This customization requires building Torizon OS with the Yocto Project.
The initramfs-framework recipe, provided by the meta-toradex-torizon layer, lists the kernel modules to load during early userspace in the INITRAMFS_EXTRA_KMODS variable. Follow the steps below to set up your environment and add the driver to the initramfs-framework recipe:
  1. Complete the host machine setup described in Host Machine Setup for Building with Yocto. After completing the prerequisites, cd into the oe-core folder:
    $ cd $HOME/oe-core
  2. Follow the Custom Meta Layers, Recipes and Images in Yocto Project (hello-world Examples) article to create the meta-customer layer. Then, create the required directory structure and the .bbappend file:
    $ cd ../layers/meta-customer
    $ mkdir -p recipes-core/initramfs-framework
    $ touch recipes-core/initramfs-framework/initramfs-framework_1.0.bbappend
  3. Update the .bbappend file, appending the module name to INITRAMFS_EXTRA_KMODS for the target MACHINE:
    INITRAMFS_EXTRA_KMODS:append:<machine> = " <module_name>"
    Replace <machine> with the target MACHINE, for example verdin-imx8mp, and <module_name> with the display driver's kernel module name. If the driver has dependency modules, append them as well. The modules are probed in the same order they are added to INITRAMFS_EXTRA_KMODS.
  4. Build and deploy the image as described in Build Torizon OS from Source With Yocto Project/OpenEmbedded.
After deploying the image, the display driver loads during early userspace, and the splash screen appears at boot again.
Touch Screen Calibration​
To calibrate your touch screen, please read the article Touch Screen Calibration (Torizon).
Testing Display and Touch​
After enabling the Device Tree Overlays, deploying it, and rebooting the board, check if the Linux system can find your display:
# find /sys/devices -name "edid"
To test the display functionality, run the Weston Wayland Compositor container (which is based on the Debian Bookworm release). The display will show a GUI with touch support. To pull the Weston container and start it on the module, run the appropriate commands for your hardware:
# docker container run -d --name=weston --net=host \
--cap-add CAP_SYS_TTY_CONFIG \
--device-cgroup-rule="c 4:* rmw" --device-cgroup-rule="c 253:* rmw" \
--device-cgroup-rule="c 13:* rmw" --device-cgroup-rule="c 226:* rmw" \
--device-cgroup-rule="c 10:223 rmw" --device-cgroup-rule="c 199:0 rmw" \
torizon/weston-imx8:4 \
--developer
To learn more about the device_cgroup_rules section of the docker-compose file above, please refer to the Hardware Access through Control Group Rules (cgroup) section of the Torizon Best Practices Guide
To launch the weston-terminal, execute it inside the container:
# docker exec weston weston-terminal
After sending the command, the Weston Terminal should start:
Weston with Wayland Terminal opened (Click on the upper left corner icon to open the terminal)
Display Output, Resolution and Timings​
Torizon OS uses the Linux Direct Rendering Manager (DRM) with Kernel Mode Setting (KMS). Learn more on the DRM/KMS section from our article Display Output, Resolution and Timings (Linux). To follow some of the instructions that use the modetest program, you can install the package libdrm-tests in one of our Debian Containers for Torizon, such as torizon/weston:
## apt update && apt install libdrm-tests
Common Display Configuration With Weston​
Customers are often interested in configurations such as rotating the display by 90 degrees or using multiple displays concurrently.
Many of these configurations can be done with Weston. Read the article Working with Weston on Torizon OS to learn more.
