Apalis Heatsink
Apalis Heatsink
(Double-Click to Zoom)
Getting Started
The heatsink is an aluminium part which is used to dissipate the heat. It is a complete thermal solution. If needed for a specific application a fan may be mounted on the heatsink.
What I need to order
The Apalis Heatsink can be ordered with Apalis modules.
Where do I order
Having trouble?
Features
Main Features
  • Provide complete thermal solution for the Apalis modules
  • Very easy to mount on the Apalis carrier board using 4x M3 (Steel-M3x10mm) screws included in the package
  • Provide screw holes to mount a DC fan to the Apalis Heatsink, if required
  • Reliable out-of-the-box fastening method
Datasheets
Datasheet
Apalis Heatsink Datasheet
Additional resources
Design Resources
Mechanical Models
It is a generic STEP model that can be opened and modified in any 3D CAD. It includes Type 1, 2, 3 and 4.
Compatible Products
Compatibility Chart
Apalis Heatsink TypeCompatible Module
Type 1Apalis iMX6Q IT
Apalis iMX6D IT
Type 2Apalis T30
Type 3Apalis iMX6Q
Apalis iMX6D
Apalis TK1
Type 4Apalis iMX8
Apalis iMX8X [1]
[1] Apalis iMX8X is only supported by the Apalis Heatsink 4 V1.0B onward.
Revision History
Product Number (PID8) Format
Product Numbering Scheme
FieldDescription
Example
0029: Apalis iMX6D 512MB
00: Assembly Variant A
2305xxxx - Apalis Heatsink Type 1
Product #Product DescriptionChanges from Previous VersionRelease DateRelated Documents
23051000
Apalis Heatsink Type 1 V1.0A
Initial Release
2014-12-31
PCN Apalis Heatsink Type 1 V1.0A 2018-05-30
23051001
Apalis Heatsink Type 1 V1.0B
New Thermal Interface Material (TIM)
2018-05-30
2306xxxx - Apalis Heatsink Type 2
23061000
Apalis Heatsink Type 2 V1.0A
Initial Release
2014-11-07
PCN Apalis Heatsink Type 2 V1.0A 2018-05-30
23061001
Apalis Heatsink Type 2 V1.0B
2018-05-30
2307xxxx - Apalis Heatsink Type 3
23071000
Apalis Heatsink Type 3 V1.0A
Initial Release
2014-11-07
PCN Apalis Heatsink Type 3 V1.0A 2018-05-30
23071001
Apalis Heatsink Type 3 V1.0B
2018-05-30
2308xxxx - Apalis Heatsink Type 4
23081000
Apalis Heatsink Type 4 V1.0A
Initial Release
2018-11-30
Do not support the Apalis iMX8X modules
23081001
Apalis Heatsink Type 4 V1.0B
- TIM thickness changed from 1.1mm to 1.2mm
2021-06-08
Support the Apalis iMX8X modules
Errata
None
