Apalis Heatsink Fan
Getting Startedβ
Toradex just added a connector to the Fan
in order to make it plug and play with our Apalis carrier boards 1x3 pin header. Please refer to the Selecting a Heatsink Fan for Apalis SoMs article to know more about fans on Apalis SoMs in general.
This product is for evaluation purposes only. It wasn't thoroughly tested by Toradex and therefore cannot be recommended for volume production.
What do I need to orderβ
The Apalis Heatsink Fan can be ordered with Apalis modules.
Where do I orderβ
See the following table for individual parts from alternate suppliersΒΉ:
Number | Part | Suppliers |
1 | Fan Delta Electronics AFB0412MA-A | Digikey Mouser |
2 | Molex 0022013037 | Digikey Mouser |
3 | KK 254 Crimp Terminal, 22-30 AWG | Digikey Mouser |
ΒΉ Those items are suggestions to speed up the customer development process. Make sure to check the details on Selecting a Heatsink Fan for Apalis SoMs.
Having trouble?β
Please contact our technical support. Various options for technical support are mentioned in the article below.
Featuresβ
Main Featuresβ
- 5000 RPM rated speed
- Reverse polarity protection
Datasheetsβ
Datasheetβ
Apalis Heatsink Fan V1.1A Datasheet Apalis Heatsink Fan V1.0A Datasheet
Additional resourcesβ
Compatible Productsβ
- Apalis iMX6
- Apalis T30
- Apalis TK1
- Apalis iMX8
- Apalis iMX8X
- Apalis Evaluation Board
- Ixora Carrier Board
- Apalis Heatsink (all types)
Revision Historyβ
Product Number (PID8) Formatβ
Field | Description |
PPPP | 4-digits number, indicating the Product Configuration (PID4) that describes the key properties of the product (e.g. Product Group, RAM capacity, etc.) |
VV | 2-digits number, indicating the Major and Minor Version (in that order) |
AA | 2-digits number, indicating the Assembly Variant |
Exampleβ
0029: Apalis iMX6D 512MB11: Major Version 1, Minor Version 1, Version V1.1 in short
00: Assembly Variant A
2309xxxx - Apalis Heatsink Fanβ
Product # | Product Description | Changes from Previous Version | Release Date | PCN Document |
23091000 | Apalis Heatsink Fan V1.0A | Initial Release | January 2021 | No PCN, for this evaluation product |
23091100 | Apalis Heatsink Fan V1.1A | Changed fan part number from Sunon MF40101V2-1000U-G99 to Delta Electronics AFB0412MA-A for improved screw mounting experience | April 2021 |
Errataβ
None
