Aster Carrier Board
Aster Carrier Board Top
Aster Carrier Board Bottom
(Double-Click to Zoom)
The Aster Carrier Board is a carrier board that gives you easy access to a selected set of the interfaces of the Colibri System on Modules (SoMs), intended as a development/evaluation platform.
Aster has been designed primarily considering Colibri VFxx System on Modules, but it's compatible with all the products in the Colibri family. It targets students, makers, and hobbyists, and includes headers compatible with Arduino Uno and Raspberry Pi (RPi) maker boards, letting you use a variety of third-party modules and add-on boards like Arduino shields and Raspberry Pi adapter boards.
This page provides hardware design resources, documentation, revision history, erratas, compatibility details, and getting started guides for developers working with the Colibri SoM family.
Getting Started​
Recommendation for the First-Time Order​
Quickstart Guide​
Check out our guide for detailed instructions on how to get your board up and running with Torizon:
Having trouble?​
Product Features​
Hardware Features​
Components​
Compatible Products​
Accessories & Add-ons​
Check other options and compatibility information on the add-ons product pages.
Block Diagram​
* Please note that these features are module-specific and may not be supported by all the computer-on-modules in the Colibri family. For more details, refer to the datasheet of Colibri computer-on-modules.
Pinout Evaluation & Planning​
Product Documents​
Datasheets​
Aster Carrier Board V1.1
Design Resources​
Aster Carrier Board Design Data V1.1
Aster Carrier Board Mechanical Models​
A basic 3D model for the Aster Carrier Board can be downloaded here:
Design and Layout Guide​
Altium Designer​
Software Ecosystem​
Toradex-Supported Linux Platforms​
Industry and Partner Software Ecosystem​
Development Resources​
Installing the Operating System​
Connecting to the Board​
Applying Settings for your Hardware Combination​
With the terminal connection to the board, select the appropriate Device Tree for your board and reboot the device. This is the main configuration needed to match your SoM to the carrier board.
# sudo fw_setenv fdtfile <som-designation>-<wifi/nonwifi>-<carrier-board-designation>.dtb
The placeholders identify the SoM, Wi-Fi variant (where applicable), and carrier board. The exact naming varies by module family.
Example for Colibri iMX6 DualLite on the Aster Carrier Board:
# sudo fw_setenv fdtfile imx6dl-colibri-aster.dtb
Refer to Device Trees on Toradex System on Modules to find the device tree for your SoM and carrier board combination. Use the corresponding .dts filename with the extension changed to .dtb.
Revision History​
Product Number (PID8) Format
Product Numbering Scheme
FieldDescription
Example
0029: Apalis iMX6D 512MB
00: Assembly Variant A
0143 Aster Carrier Board​
01431000
Aster V1.0A
Initial Release
Q2 2016Obsolete
01431100
Aster V1.1A
Fixed VGA polarity issue with Vybrid
Fixed shared USB host/client issue when other USB devices are connected
Q1 2017
01431101
Aster V1.1B
Added JTAG through pogo pins and X6Feb 2017
Errata/Known Issues​
Errata Document​
None
