Ivy Carrier Board
Getting Started
This section contains initial information needed to set-up the Ivy Carrier Board for the first time.
Recommendation for the first-time order
Ivy Carrier Board is available at the Toradex Webshop in two possible models: Ivy Carrier Board and Ivy Plus Carrier Board. Please check the Ivy vs Ivy Plus section for more details about each model. Toradex recommends ordering the following additional products for your first-time order:
Getting started
The Verdin SoMs come with Toradex Easy Installer pre-installed. Once you power-on the board, it will display a list of available images to be installed. Check out how to get started with the Toradex Easy Installer:
Additional information
For information on how to re-flash an operating system or image on the computer on module please check the Toradex Easy Installer article:
We have quick video tutorials:
For developing software on the platform, please browse through the list of knowledge-base articles provided in the link below:
Having trouble?
Please contact our technical support. Various option of technical support are mentioned below:
Hardware Features
Check the hardware features on the product page in toradex.com:
Block Diagram
Ivy Carrier Board V1.1
Ivy Carrier Board V1.0
Datasheets
Ivy Carrier Board Preliminary Release
Design Resources
The resources provided here are for informational purposes only and are intended to aid developers in understanding the existing product design for development and helping integrating the product. The schematics are not intended to be copied or used as a reference design.
Ivy Carrier Board V1.1 Design Data
- Ivy Carrier Board V1.1 Altium project
- Ivy Carrier Board V1.1 Assembly Drawing
- Ivy Carrier Board V1.1 PDF Schematics
- Ivy Carrier Board V1.1 Bill of Materials (BOM)
- Ivy Plus Carrier Board V1.1 PDF Schematics
- Ivy Plus Carrier Board V1.1 Bill of Materials (BOM)
Ivy Carrier Board V1.0 Design Data
- Ivy Carrier Board V1.0 Altium project
- Ivy Carrier Board V1.0 Assembly Drawing
- Ivy Carrier Board V1.0 PDF Schematics
- Ivy Carrier Board V1.0 Bill of Materials (BOM)
- Ivy Plus Carrier Board V1.0 PDF Schematics
- Ivy Plus Carrier Board V1.0 Bill of Materials (BOM)
Verdin Specifications
Ivy Carrier Board V1.1 Mechanical Models
You can download a basic 3D model for Ivy Carrier Board V1.1 here:
Ivy Carrier Board V1.0 Mechanical Models
You can download a basic model for the Ivy Carrier Board V1.0 here:
Design and Layout Guide
Design and Layout Guide is not yet available on the new developer website.
Altium Designer
Ivy Mating Connectors
Connectors J5 and J6
| Connector Side | Manufacturer | PN | Shop link |
| Ivy connector(placed in the board) | Weidmueller | 1728700000 | |
| Mating connector | Weidmueller | 1277760000 | Mouser/Digikey |
| Mating connector | Weidmueller | 1277940000 | Mouser/Digikey |
Ivy vs Ivy Plus Comparison
| Feature | 0175XXXX - Ivy | 0178XXXX - Ivy Plus |
| Power Supply Range | 8 to 32V (12V or 24V nominal) | 21 to 72V (24V or 48V nominal) |
| CAN | 2X (with transceiver, non-isolated) | 2X (with transceiver, isolated) |
| RS-232 | 1X (with transceiver, non-isolated) | 1X (with transceiver, isolated) |
| RS-485 | 1X (with transceiver, non-isolated) | 1X (with transceiver, isolated) |
| Gigabit ETH | 2 | 2 |
| Analog Input | Non-isolated | Isolated |
| TPM | Non included | Included |
| FRAM | Non included | 32KB |
| All other features | Yes | Yes |
Ivy Compatibility
| Verdin Modules | Product Number | USB | Ethernet | PCIe | RS232 | RS485 | CAN | Display Serial Interface |
| Verdin AM62 Dual 1GB ET | 0073XXXX | 2x Host / 1x OTG | 2x | No | Yes | Yes | Yes | Yes |
| Verdin AM62 Dual 1GB IT | 0074XXXX | 2x Host / 1x OTG | 2x | No | Yes | Yes | Yes | Yes |
| Verdin AM62 Dual 1GB Wi-Fi / Bluetooth IT | 0075XXXX | 2x Host / 1x OTG | 2x | No | Yes | Yes | Yes | Yes |
| Verdin AM62 Quad 2GB Wi-Fi / Bluetooth IT | 0076XXXX | 2x Host / 1x OTG | 2x | No | Yes | Yes | Yes | Yes |
| Verdin AM62 Solo 512MB | 0071XXXX | 2x Host / 1x OTG | 2x | No | Yes | Yes | Yes | No |
| Verdin AM62 Solo 512MB Wi-Fi / Bluetooth IT | 0072XXXX | 2x Host / 1x OTG | 2x | No | Yes | Yes | Yes | No |
| Verdin iMX8M Mini DualLite 1GB | 0057XXXX | 2x Host / 1x OTG | 1x | 1x Single Lane Gen 2 | Yes | Yes | No | Yes |
| Verdin iMX8M Mini DualLite 1GB Wi-Fi / Bluetooth IT | 0060XXXX | 2x Host / 1x OTG | 1x | 1x Single Lane Gen 2 | Yes | Yes | No | Yes |
| Verdin iMX8M Mini Quad 2GB IT | 0059XXXX | 2x Host / 1x OTG | 1x | 1x Single Lane Gen 2 | Yes | Yes | 1x (CAN FD) | Yes |
| Verdin iMX8M Mini Quad 2GB Wi-Fi / Bluetooth IT | 0055XXXX | 2x Host / 1x OTG | 1x | 1x Single Lane Gen 2 | Yes | Yes | 1x (CAN FD) | Yes |
| Verdin iMX8M Mini Quad 2GB Wi-Fi / Bluetooth IT (No CAN) | 0068XXXX | 2x Host / 1x OTG | 1x | 1x Single Lane Gen 2 | Yes | Yes | No | Yes |
| Verdin iMX8M Plus Quad 2GB Wi-Fi / Bluetooth IT | 0064XXXX | 2x Host / 1x OTG | 2x | 1 Single Lane Gen 3 | Yes | Yes | Yes | Yes |
| Verdin iMX8M Plus Quad 4GB IT | 0063XXXX | 2x Host / 1x OTG | 2x | 1 Single Lane Gen 3 | Yes | Yes | Yes | Yes |
| Verdin iMX8M Plus Quad 4GB Wi-Fi / Bluetooth IT | 0058XXXX | 2x Host / 1x OTG | 2x | 1 Single Lane Gen 3 | Yes | Yes | Yes | Yes |
| Verdin iMX8M Plus Quad 8GB Wi-Fi / Bluetooth IT | 0070XXXX | 2x Host / 1x OTG | 2x | 1 Single Lane Gen 3 | Yes | Yes | Yes | Yes |
| Verdin iMX8M Plus QuadLite 1GB IT | 0065XXXX | 2x Host / 1x OTG | 2x | 1 Single Lane Gen 3 | Yes | Yes | Yes | Yes |
Compatible Products
- Verdin AM62
- Verdin iMX8M Mini
- Verdin iMX8M Plus
- Verdin Industrial Heatsink
- Capacitive Touch Display 10.1" DSI
- Capacitive Touch Display 7" DSI
Revision History
Product Number (PID8) Format
| Field | Description |
Example
0029: Apalis iMX6D 512MB
00: Assembly Variant A
Ivy Carrier Board
PN: 0175
| Product # | Product Description | Changes from Previous Version | Release Date | Related Documents |
| 01751000 | Ivy V1.0A | Preliminary Version | Q4 2024 | PCN 01751000 Ivy V1.0A to 01751100 Ivy V1.1A |
| 01751100 | Ivy V1.1A | Fixed Errata HAR-11662 Fixed Errata HAR-11742 Changed switches PN - S1 and S2 Other minor changes and fixes | Q3 2025 |
PN: 0178
| 01781000 | Ivy Plus V1.0A | Preliminary Version | Q4 2024 | Preliminary Version - No PCN document |
| 01781100 | Ivy Plus V1.1A | Fixed Errata HAR-11662 Fixed Errata HAR-11742 Other minor changes and fixes | Q3 2025 |
