Torizon IDE Extension for VS Code
Torizon offers ready-to-use integration with Visual Studio Code. The IDE Extension for VS Code brings all the convenience of modern development tools to embedded and IoT product development. Including Full Remote Debug capabilities and integration with CI/CD toolchains. The extension allows you to get started in just minutes.
Read the full overview article on the Torizon IDE Extension for VS Code to learn more.
Documentation Summary
Feature Guides
- Set up the Torizon IDE Extension Environment
- Create a Torizon Project
- Connect a Torizon OS Target Device
- Remote Debug and Deploy Projects
- Add Packages, Libraries and Tools to Existing Projects
- Pass Arguments to Containerized Applications
- Build, Test and Push Applications for Production
- Update Project from Template
- Edit a Torizon Project
Development Workflow Examples
- Application Development - .NET Example
- Application Development - Python Example
- Application Development - C/C++ Example
CI/CD Workflow
- CI/CD - Configure Projects to Run CI Pipelines
- CI/CD - Integrate With GitHub Actions
- CI/CD - Integrate With GitLab CI Pipelines
