Version: Torizon OS 7.x.y
Build, Test and Push Applications for Production
The Torizon IDE Extension offers multiple tasks for managing application containers after the debugging phase is complete:
Prerequisites​
Build and Test Release Container Images​
You can build and run containers through the run-container-torizon-release-<arch> task, which performs the following steps:
  1. Build a container image based on Dockerfile.
  2. Push the container image to the local container registry (localhost:5002).
  3. Pull the container image to your SoM set as the default target.
  4. Run the container on your SoM using the docker-compose.yml configuration.
When debugging applications, the container is built based on Dockerfile.debug. That file contains additional dependencies and settings to enable remote debugging on VS Code. Instead, the run-container-torizon-release-<arch> task builds the container with only the essential configuration. You can use that task to test your application before moving it to production.
To run run-container-torizon-release-<arch> task, follow the steps below:
  1. Click on the Explorer icon located on the VSCode Activity bar.
  2. Open the TASK RUNNER tab.
  3. Click on the task.
Prepare your Application Container for Production​
The create-production-image task performs the following steps:
  2. Push the container image to a container registry, such as DockerHub.
  3. Create the docker-compose.prod.yml file.
The docker-compose.prod.yml file is automatically created based on docker-compose.yml:
  • The -debug services are removed.
  • Environment variables, such as DOCKER_LOGIN and TAG, are replaced with user inputs.
  • The build configuration is removed.
You can use the .yml file to create application packages on Torizon Cloud.
warning
Do not edit the docker-compose.prod.yml file. To change the rules or services of docker-compose.prod.yml, edit the docker-compose.yml file and run the create-production-image task again.
When triggered, the create-production-image task requires the following inputs:
  • Docker registry: The container registry to which the task pushes the image. If empty, the task uses DockerHub. However, you can use any other registry, like GitHub and Azure.
  • Docker registry user login: The task uses the user login to set the image's name, which will be userLogin/applicationName:dockerTag.
  • Docker registry password: the Docker registry password or token to use to push the image to the container registry. This will be stored as a secret in the VS Code vault.
  • Docker tag to use in the production image: The container tag. The image name will be userLogin/applicationName:dockerTag.
  • Container architecture: The platform architecture to which the task compiles the container. Select the architecture that matches your target device.
Some inputs – such as the container tag – are not requested again if previously set. To change input values, edit .vscode/settings.json. For input details, see Workspace Settings.
At the finish of the task, the VS Code terminal should display the following message:
Build and Push Applications to Torizon Cloud​
You can push applications to Torizon Cloud directly from the Torizon IDE extension. The tcb-platform-publish task runs create-production-image and pushes the docker-compose.prod.yml file to Torizon Cloud, creating a new application package.
Before running the tcb-platform-publish task, proceed as follows:
  1. Get Torizon Cloud credentials.zip.
  2. Place the credentials.zip file in the root directory of your project (where Dockerfile and docker-compose.yml are located).
When triggered, the tcb-platform-publish task requires the following inputs:
  • The create-production-image inputs described in the previous section.
  • Torizon Cloud API v2 Client ID.
  • Torizon Cloud API v2 Client Secret.
See Creating a New Torizon Cloud API v2 Client for information about the API credentials.
At the finish of the task, you should see the following message in the terminal tab:
The application package will be available on Torizon Cloud:
Troubleshoot Execution Errors - Production​
Check the Debug and Deploy section.
