or cat /etc/issue
on the board.
Torizon offers a Microsoft Environment for developers familiar with Visual Studio. This article will show how to install, configure and use it to build a "hello world" application and deploy it to a target device.
There is also a trend towards using Visual Studio Code (which by the way is very different from Visual Studio, only the name is similar). If you are interested in learning more, check our article Visual Studio Code Extension for Torizon.
buildkit
is enabled in Docker When buildkit
is enabled you can't reference local images. This prevents multi-stage builds or Dockerfile referencing a local image from working. Toradex SDK uses a container that is generated on the fly and kept on the local machine and this fails with buildkit
enabled.
To fix that, please disable buildkit on the local Docker installation by or removing it from your Docker daemon configuration file at "features" section, or setting its value to false.
You must add a \n
(new line) at the end of each line to be printed through printf()
, so you can see the lines being printed during the debug session at the Linux Console Window in Visual Studio.
Without this, the output will only appear at the end of the debug session.
Access the Visual Studio Market Place and click on the Get Started button:
This will download the Visual Studio extension TorizonVSExtension.vsix file.
Warning: Before installing, make sure there are no instances of Visual Studio open.
Double click on TorizonVSExtension.vsix to start the installation. The following window below will be shown:
Select your Visual Studio version and click the Install button. Wait until the installation process is complete.
After installation, open Visual Studio for a first configuration of the work environment for Torizon. After opening Visual Studio click on Continue without code:
Directly from Visual Studio, you have access to configure important options to the Moses Service.
Warning: Currently, Windows usernames with spaces (example: FirstName LastName) are not supported and will result in a fatal error on the Moses service.
Visual Studio Extension For Torizon uses Docker container images that have all the toolchain and SDK for C/C++ development for Toradex Boards. It is recommended to download these container images before starting development. Select menu Tools -> Download update base and sdk containers :
Downloading and updating container images may take a few minutes. Wait until you have the following message in the output:
Visual Studio Extension For Torizon needs to be connected to a target device, which will be the context for deploying the developed applications. To connect to Toradex devices with Visual Studio Extension For Torizon use the Torizon Devices Explorer. Select the menu View -> Other Windows -> Torizon devices:
On the Torizon Devices Explorer click on the Detect device on the network:
The window below will be shown:
Enter the IP address of the Toradex board, which will be the target device, and the Torizon user credentials then click the Detect
button.
Note: These credentials are the same that were added during the first Torizon boot.
This detection process will perform an exchange of credentials between Visual Studio and the Toradex board to pair the board with the Torizon Visual Studio Extension.
After detection we should have in Torizon Devices Explorer a new entry for the target device. Click on Refresh to download information...
button to list the information about the Docker Images, Containers and Proccess running on the target device:
Another feature that must be enabled before we create our first project is the Torizon Toolbar. Right click on the Visual Studio toolbar and select Torizon Toolbar:
After this first environment setup we are ready to create our projects.
To create a new Torizon C/C++ project select File -> New -> Project ...:
On the Create a new project
window search for torizon
templates and double click the Torizon C/C++ Application
template:
On the Configure your new project
window:
Project name
;Location
for the project files or leave the pre-defined location;Create
button;On the create task Visual Studio will ask for Select supported platforms
. Select the platform that matches with the architecture of the target device. For this guide we are using the Apalis iMX8QM that contains a hexa-core arm64v8 processor, so we select the option debian arm64v8 bullseye
Note: Please notice that the list of platforms may change as new platforms supporting new releases of debian or providing some pre-installed libs for specific usage scenarios will be added.
This will create a blank Torizon C/C++ Application template.
After the development of your application, in the case of this guide a simple message to be written, it is time to run the application to test and debug it on the target device.
To debug your application you can enable breakpoints selecting the lines of code that you want debug:
After selecting any breakpoint in your source code, run the application to debug it. For this, click on the Deploy and debug torizon Application
, the "play" button, from Torizon Toolbar:
As shown in the GIF above, when clicking on Deploy and debug torizon Application
a window will be displayed warning that the application is not up to date, click on yes
button to build and update the application container. This will start the build, deploy and debug process.
The first time the application containers are built takes some time:
You will get the following messages in the output tab when the application container build has completed successfully:
When the build of the application container finishes Visual Studio will start the deployment onto the target device. A window to Select device...
will be shown. Select your target device to deploy from the list and click Ok
button:
The deployment of the container application to the target device can take some time during the first deployment. Wait until the deployment finishes successfully. After this the application will wait until the deployment finishes successfully. After that the application will be running on the target device and the breakpoint will be reached. Click on the Continue
button, or press the F5 key, to continue to the next instructions of the program:
After the first time, future deployments with the Deploy and debug torizon Application
command will become faster, because the container will only have to be updated on the target device, a much faster process than deploying the container as a whole:
When the application is ready, debugged and tested, it can be deployed and released. To do this switch the Debug_debian_buster-slim_<your_arch>
option to Release_debian_buster-slim_<your_arch>
in the Visual Studio toolbar Solution Configurations
Next step is to put the extension in release mode. To do this, select Project -> Properties -> Torizon C/C++ Application -> Configuration -> HelloWorld Properties and change the combo box Configuration
from Common
to Release
For the Release configuration you will need to add two new properties. Click on the New Property...
button. In the Name:
field enter targetcommands
and in the Value:
field enter CMD [ "/bin/HelloWorld.out" ]
, click OK
to apply it. For the second property click on the New Property...
button again. In the Name:
field enter targetfiles
and in the Value:
field enter COPY work/bin/ /bin/
, click OK
to apply it:
Setting the targetcommands
property is the same as adding CMD
to a Dockerfile. Here we are adding the output generated by the compiler as CMD
. In order to place the executable file we created in to the path referenced by CMD
we must copy that file to the container image. The targetfiles
property allows us to COPY
to the Dockerfile. Here we are adding the output files, bin
folder, to be copied to Docker image.
Click Save
button to apply the changes and close the Property Pages
window. Now in release mode build the application clicking on the Build Torizon Application
from the Torizon Toolbar
Wait until the build is completed. After that it is necessary to build the application container, so click on the Deploy Torizon application and container
After the deploy, refresh the list of images and containers on Torizon Devices Explorer:
You can see that now there are two images and two containers. One of these containers and image is for the debug, it will no longer be needed and can be deleted to free up space. First remove the debug container and then the image. Still using Torizon Devices Explorer click on the names listed in Containers
. The one that contains debug in your name, right click and select Delete
After that the same can be done for the debug image. Using Torizon Devices Explorer click on the names listed in Images
This section collects known issues and, if available, workarounds that are related to the Visual Studio Extension for Torizon:
Now that you have the extension set up and deployed your first hello world application, how about continuing with something more advanced?
You can use the release image for production programming. There are two phases and tools:
button.
template:
window:
Project name
;Location
. Select the platform that matches with the architecture of the target device. For this guide we are using the Apalis iMX8QM that contains a hexa-core arm64v8 processor, so we select the option debian buster-slim:arm64v8 - 1.0
button:
from Common
to Release
and in the Value:
, click OK
and in the Value:
, click OK
to apply it:
Click Save
Now that you have the extension set up and deployed your first hello world application, how about continuing with something more advanced? See these other articles using that use the Visual Studio Extension For Torizon:
