Aquila AM69/TDA4 Power Consumption
This is one of a series of posts about Toradex modules' power consumption measurements. This article provides information about the power consumption of Aquila AM69/TDA4.
The Aquila AM69/TDA4's power consumption depends on the devices connected to it. Below are the power consumption results of several test cases, demonstrating realistic system configurations at various CPU loads.
Disclaimer
  • Environmental temperature
  • Particular Silicon Revision of the SoC
  • Versions of the Software Components installed on the module
  • Use cases
Testing Conditions
  • The tests were performed using 3 different modules of each model.
  • The provided data is the average of the results obtained for each module group.
  • All of the SoMs were heated up first (using a stress test) to simulate the conditions of a continuous use scenario.
0088 Aquila AM69 Octa 32GB WB IT V1.0A
Results
Test caseMean Power Consumption [W]Peak Power Consumption [W]
Idling mode without screen and without eth12.0815.37
Idling mode without screen and with eth12.9816.81
Idling mode with screen and without eth12.1515.7
Idling mode with screen and with eth13.0817.1
Stress 1 core(s) without screen13.5817.1
Stress 2 core(s)14.3017.85
Stress 3 core(s)14.8918.71
Stress 4 core(s)15.4919
Stress 5 core(s)16.1620
Stress 6 core(s)16.8220
Stress 7 core(s)17.4420.83
Stress 8 core(s)18.0521
iperf3 with CPU Stress and eth and with screen18.1920.56
iperf3 with CPU Stress and 2.4GHz and with screen19.5522.58
iperf3 with CPU Stress and eth and 2.4GHz and with screen19.4223.16
iperf3 with CPU Stress and 5GHz and with screen19.7823.01
iperf3 with CPU Stress and eth and 5GHz and with screen19.8323.01
iperf3 eth and without screen13.6217.24
iperf3 2.4GHz and without screen14.5319.53
iperf3 5GHz and without screen15.0920.27
glmark2 with all cores stressed19.2422.01
glmark214.6019.09
max stress: stress-ng, glmark2, iperf3 and ethernet19.2522.01
max stress: stress-ng, glmark2, iperf3 wifi 2.4GHz and ethernet20.5624.17
max stress: stress-ng, glmark2, iperf3 wifi 5GHz and ethernet20.3824.44
CPU stress + video play18.2321.85
