Colibri iMX6ULL Power Consumption
Overviewโ€‹
This article provides information about the power consumption of the Colibri iMX6ULL module. This information is extracted directly from the Colibri iMX6ULL Datasheet - Section 9.2 Electrical Characteristics.
Colibri iMX6ULL module will have approx 0.4 - 1.2W power consumption depending on the interfaces used and devices connected to it. Below are the power consumption results of several test cases demonstrating realistic system configurations at various CPU loads for the Colibri iMX6ULL module.
Disclaimerโ€‹
  • Environmental temperature
  • Particular Silicon Revision of the SoC
  • Versions of the Software Components installed on the module
  • Use cases
Testing Conditionsโ€‹
  • The tests were performed using 3 different modules of each model.
  • The provided data is the average of the results obtained for each module group.
  • All of the SoMs were heated up first (using a stress test) to simulate the conditions of a continuous use scenario.
For a description of each power mode, read the Colibri iMX6ULL Datasheet - Section 6. Power Management.
For the calculation of power consumption, it was considered a 3.3V supply.
Colibri iMX6ULL 256MBโ€‹
Software version: To be determined
Resultsโ€‹
DescriptionTypical Consumption (mA)Power (W)
Maximum CPU Load1870.617
CPU Idle1420.468
CPU in Low Power Mode1130.373
Module in Suspend State130.043
Colibri iMX6ULL 512MB ITโ€‹
Resultsโ€‹
Maximum CPU LoadTBDTBD
CPU IdleTBDTBD
CPU in Low Power ModeTBDTBD
Module in Suspend StateTBDTBD
Colibri iMX6ULL 512MB WB ITโ€‹
Resultsโ€‹
Maximum CPU Load with Wi-Fi Streaming3491.152
CPU Idle1750.578
CPU in Low Power Mode1440.475
Colibri iMX6ULL 512MB WBโ€‹
Resultsโ€‹
CPU IdleTBDTBD
0062 Colibri iMX6ULL 1GB IT V1.1Aโ€‹
Resultsโ€‹
Test CaseAverage [W*]Maximum [W*]
RTC clock (proper shutdown)2.56 ยตW-
RTC clock (power cable removing shutdown )2.72 ยตW-
Suspend mode (standby)0.070.00
Suspend mode (mem)0.030.00
Idling mode with screen0.480.57
Idling without screen0.470.56
Stress 1 cores0.720.97
CPU burn - neon stress script0.670.68
Max stress: all cores stressed, iperf3 Ethernet0.760.94
iperf3 Ethernet no screen0.560.59
  • Unless explicitly mentioned
Additional Resourcesโ€‹
Product Page and Datasheet: Colibri iMX6ULL
Specifications and Design Guides: Carrier Board Design Guides
Thermal Management in Toradex Modules: Thermal Management
How to Suspend Your Module Running Linux: Suspend/Resume (Linux)
