Verdin AM62 Power Consumption
This is one of a series of posts about Toradex modules' power consumption measurements. This article provides information about the power consumption of Verdin AM62.
The Verdin AM62's power consumption depends on the devices connected to it. Below are the power consumption results of several test cases, demonstrating realistic system configurations at various CPU loads.
Disclaimer
- Environmental temperature
- Particular Silicon Revision of the SoC
- Versions of the Software Components installed on the module
- Use cases
Testing Conditions
- The tests were performed using 3 different modules of each model.
- The provided data is the average of the results obtained for each module group.
- All of the SoMs were heated up first (using a stress test) to simulate the conditions of a continuous use scenario.
0071 Verdin AM62 Solo 512MB
Results
- Software Distribution: BSP Layers and Reference Images for Yocto Project Software: TDX Wayland
- Software Image: BSP Layers and Reference Images for Yocto Project Software 6.7.0 Build 13 (kirkstone) verdin-am62
Test case | Mean Power Consumption [W] | Peak Power Consumption [W] |
Idlling mode without screen and withouth eth | 0.91 | 1.66 |
Idlling mode without screen and with eth | 1.56 | 2.31 |
Idlling mode with screen and withouth eth | 0.93 | 1.90 |
Idlling mode with screen and with eth | 1.58 | 2.51 |
Stress 1 core(s) without screen | 1.64 | 2.43 |
iPerf3 with CPU Stress and eth and with screen | 1.72 | 2.62 |
iPerf3 eth and without screen | 1.71 | 2.53 |
cpu neon stress script | 1.71 | 2.64 |
suspend mode idle | 59.7mW | 69.16mW |
0072 Verdin AM62 Solo 512MB WB IT
Results
Idlling mode without screen and withouth eth | 0.89 | 1.64 |
Idlling mode without screen and with eth | 1.56 | 2.32 |
Idlling mode with screen and withouth eth | 0.89 | 1.67 |
Idlling mode with screen and with eth | 1.57 | 2.30 |
Stress 1 core(s) without screen | 1.66 | 2.45 |
iPerf3 with CPU Stress and eth and with screen | 1.72 | 2.60 |
iPerf3 with CPU Stress and 5GHz and with screen | 2.22 | 3.75 |
iPerf3 with CPU Stress and eth and 5GHz and without screen | 2.26 | 3.79 |
iPerf3 eth and without screen | 1.82 | 2.69 |
iPerf3 5GHz and without screen | 2.18 | 3.79 |
cpu neon stress script | 1.79 | 2.54 |
suspend mode idle | 117.3mW | 125.35mW |
0073 Verdin AM62 Dual 1GB ET
Results
Idlling mode without screen and withouth eth | 1.07 | 1.85 |
Idlling mode without screen and with eth | 1.72 | 2.47 |
Idlling mode with screen and withouth eth | 1.16 | 2.16 |
Idlling mode with screen and with eth | 1.81 | 2.79 |
Stress 1 core(s) without screen | 1.90 | 2.66 |
Stress 2 core(s) | 2.12 | 3.13 |
iPerf3 with CPU Stress and eth and with screen | 2.19 | 3.18 |
iPerf3 eth and without screen | 2.02 | 3.02 |
cpu neon stress script | 2.33 | 3.35 |
suspend mode idle | 62.97mW | 78.34mW |
0074 Verdin AM62 Dual 1GB IT
Results
Idlling mode without screen and withouth eth | 1.04 | 1.89 |
Idlling mode without screen and with eth | 1.69 | 2.52 |
Idlling mode with screen and withouth eth | 1.13 | 2.22 |
Idlling mode with screen and with eth | 1.78 | 2.84 |
Stress 1 core(s) without screen | 1.88 | 2.73 |
Stress 2 core(s) | 2.08 | 3.19 |
iPerf3 with CPU Stress and eth and with screen | 2.14 | 3.25 |
iPerf3 eth and without screen | 1.99 | 3.08 |
glmark2 with all cores stressed | 2.22 | 3.27 |
glmark2 | 2.01 | 3.09 |
max stress: all cores stressed, glmark2, iperf3 and ethernet | 2.22 | 3.33 |
max stress: burn-a53, glmark2, iperf3 and ethernet | 2.30 | 3.48 |
cpu neon stress script | 2.30 | 3.44 |
suspend mode idle | 64.72mW | 73mW |
0075 Verdin AM62 Dual 1GB WB IT
Results
Idlling mode without screen and withouth eth | 1.18 | 2.11 |
Idlling mode without screen and with eth | 1.84 | 2.69 |
Idlling mode with screen and withouth eth | 1.27 | 2.29 |
Idlling mode with screen and with eth | 1.92 | 2.97 |
Stress 1 core(s) without screen | 2.01 | 2.83 |
Stress 2 core(s) | 2.23 | 3.34 |
iPerf3 with CPU Stress and eth and with screen | 2.29 | 3.31 |
iPerf3 with CPU Stress and 5GHz and with screen | 2.75 | 4.34 |
iPerf3 with CPU Stress and eth and 5GHz and without screen | 2.58 | 4.29 |
iPerf3 eth and without screen | 2.20 | 3.25 |
iPerf3 5GHz and without screen | 2.42 | 4.03 |
glmark2 with all cores stressed | 2.44 | 3.53 |
glmark2 | 2.22 | 3.26 |
max stress: all cores stressed, glmark2, iperf3 and ethernet | 2.42 | 3.59 |
max stress: all cores stressed, glmark2, iperf3 wifi 5GHz and ethernet | 2.69 | 4.31 |
max stress: burn-a53, glmark2, iperf3 and ethernet | 2.52 | 3.59 |
max stress: burn-a53, glmark2, iperf3 wifi 5GHz and ethernet | 2.83 | 4.60 |
cpu neon stress script | 2.51 | 3.63 |
suspend mode idle | 133.38mW | 182.63mW |
0076 Verdin AM62 Quad 2GB WB IT
Results
Idlling mode without screen and withouth eth | 1.20 | 2.02 |
Idlling mode without screen and with eth | 1.87 | 2.56 |
Idlling mode with screen and withouth eth | 1.29 | 2.25 |
Idlling mode with screen and with eth | 1.94 | 2.88 |
Stress 1 core(s) without screen | 2.05 | 2.76 |
Stress 2 core(s) | 2.25 | 3.21 |
Stress 3 core(s) | 2.38 | 3.37 |
Stress 4 core(s) | 2.50 | 3.49 |
iPerf3 with CPU Stress and eth and with screen | 2.55 | 3.58 |
iPerf3 with CPU Stress and 5GHz and with screen | 3.04 | 4.62 |
iPerf3 with CPU Stress and eth and 5GHz and without screen | 2.80 | 4.58 |
iPerf3 eth and without screen | 2.23 | 3.22 |
iPerf3 5GHz and without screen | 2.47 | 3.92 |
glmark2 with all cores stressed | 2.67 | 3.63 |
glmark2 | 2.22 | 3.15 |
max stress: all cores stressed, glmark2, iperf3 and ethernet | 2.66 | 3.66 |
max stress: all cores stressed, glmark2, iperf3 wifi 5GHz and ethernet | 2.77 | 4.59 |
max stress: burn-a53, glmark2, iperf3 and ethernet | 3.02 | 4.11 |
max stress: burn-a53, glmark2, iperf3 wifi 5GHz and ethernet | 3.12 | 5.19 |
cpu neon stress script | 3.08 | 4.06 |
suspend mode idle | 125.25mW | 171.16mW |
