SMARC iMX95 Power Consumption
This is one of a series of posts about Toradex modules' power consumption measurements. This article provides information about the power consumption of SMARC iMX95.
The SMARC iMX95's power consumption depends on the devices connected to it. Below are the power consumption results of several test cases, demonstrating realistic system configurations at various CPU loads.
Disclaimer
- Environmental temperature
- Particular Silicon Revision of the SoC
- Versions of the Software Components installed on the module
- Use cases
Testing Conditions
- The tests were performed using 3 different modules of each model.
- The provided data is the average of the results obtained for each module group.
- All of the SoMs were heated up first (using a stress test) to simulate the conditions of a continuous use scenario.
0096 SMARC iMX95 Hexa 8GB WB IT V1.0A
Results
- Software Distribution: BSP Layers and Reference Images for Yocto Project Software: TDX Wayland
- Software Image: BSP Layers and Reference Images for Yocto Project Software 7.3.0-devel-20250514+build.336 (scarthgap)
Test case | Mean Power Consumption [W] | Peak Power Consumption [W] |
Suspend mode idle | 0.15 | 0.40 |
Idling mode without screen and without Ethernet | 2.99 | 6.48 |
Idling mode without screen and with Ethernet | 3.85 | 7.07 |
Idling mode with screen and without Ethernet | 3.89 | 6.86 |
Idling mode with screen and with Ethernet | 4.70 | 7.68 |
Stress 1 core(s) without screen | 4.39 | 6.34 |
Stress 2 core(s) | 5.36 | 7.11 |
Stress 3 core(s) | 5.61 | 7.30 |
Stress 4 core(s) | 5.87 | 8.21 |
Stress 5 core(s) | 6.17 | 8.51 |
Stress 6 core(s) | 6.46 | 9.00 |
iperf3 with CPU Stress, Ethernet and with screen | 6.53 | 8.51 |
iperf3 with CPU Stress, 2.4GHz and with screen | 6.98 | 8.81 |
iperf3 with CPU Stress, Ethernet, 2.4GHz and with screen | 7.08 | 8.97 |
iperf3 with CPU Stress, 5GHz and with screen | 7.27 | 9.47 |
iperf3 with CPU Stress, Ethernet, 5GHz and with screen | 7.34 | 9.52 |
iperf3 Ethernet and without screen | 4.47 | 7.31 |
iperf3 2.4GHz and without screen | 4.67 | 8.52 |
iperf3 5GHz and without screen | 5.52 | 9.46 |
glmark2 with all cores stressed | 6.82 | 9.60 |
glmark2 | 5.09 | 9.91 |
Max stress: stress-ng, glmark2, iperf3 and Ethernet | 6.86 | 9.65 |
Max stress: stress-ng, glmark2, iperf3 wifi 2.4GHz and Ethernet | 7.37 | 10.36 |
Max stress: stress-ng, glmark2, iperf3 wifi 5GHz and Ethernet | 7.60 | 10.62 |
CPU stress + video play | 6.59 | 8.38 |
Poweroff state | 0.00 | 0.20 |
