Windows CE Library - General Purpose Input Output Library (GPIOLIb)
Description
This library manages General Purpose IO pins.
Current Version
V2.3
Application Notes
The GPIOLib provides functions to interact with GPIO pins - pins can be referenced using SODIMM pin numbers or processor-specifc GPIO pin numbers. Individual functions in the library require a specific type of pin reference type. For portability, SODIMM pin numbers and associated functions are recommended. In some application-specific instances processor-specific GPIO pin numbers will need to be used.
SODIMM pin numbers are numeric. Our datasheets use an alphanumeric format. Conversion between the two formats is detailed here.
Some SODIMM pins have multiple GPIO pins multiplexed on to them - consult the datasheet for your module for specific details.
Library API
Other Resources
Windows CE Libraries Overview
How to use GPIO library
GPIO Alphanumeric to GPIO Numeric Assignment
GPIOConfig Tool
Second instance GPIO
GPIO config block settings
How to use GPIO library in VB.net
How to use GPIO library in VCSharp
How to use matrix keypad
Revision History
DateRevChange Notes
11/03/2014V2.3Improve support for Colibri T30 (InitGpioLibEx())
Fixed issue with SODIMM pin 133 on Colibri T30
23/09/2013V2.2.1Change default SDK to Colibri600 / Fix mapping of GPIO BB0
12/08/2013V2.2.0Fixed GPIO Input enable issue on T30
17/06/2013V2.1.3Updated to work with Apalis T30
