Sys Info Lib API
Library to provide access to System Information. More...
Data Structures
struct _PROCESSOR_INFO struct BB_RELOCMacros | |
#define | SIL_VER_MAJ 1 |
See also SysInfoLibDemo. More... | |
#define | SIL_VER_MIN 4 |
#define | SIL_VER_BUILD 0 |
#define | TYPE_NOR 0x01 |
#define | TYPE_NAND 0x02 |
Typedefs | |
typedef struct _PROCESSOR_INFO | PROCESSOR_INFO |
Functions | |
BOOL | SysInfoLibInit (void) |
BOOL | SysInfoLibDeInit (void) |
BOOL | GetOSVersion (LPOSVERSIONINFO pOSInfo) |
BOOL | GetImageInfo (BSPVER *pBspVer, SYSTEMTIME *pBspDate) |
BOOL | GetBootloaderInfo (BSPVER *pBspVer, SYSTEMTIME *pBspDate) |
BOOL | GetSystemSpeeds (DWORD *pCpuSpeed, DWORD *pRamSpeed, DWORD *pBusSpeed) |
BOOL | GetProcessorInfo (PROCESSOR_INFO *pPI) |
BOOL | GetBoardVersion (HWCFG *pHWVer) |
BOOL | GetBoardSerial (DWORD *pSerial) |
BOOL | GetMACAddress (BYTE *pMAC) |
BOOL | SetMACAddress (BYTE *pMAC) |
DWORD | GetFlashSize (DWORD *pFlashType) |
DWORD | GetMemorySize (void) |
BOOL | GetBBTable (BB_RELOC *reloc, DWORD *numReloc) |
DWORD | SetFrequencyPXA270 (DWORD l, DWORD n, BOOL turbo, BOOL turbo2, BOOL fastBus, BOOL altmem, BOOL sram2) |
DWORD | SetFrequencyPXA3xx (DWORD l, DWORD n, DWORD hsio, DWORD sram, DWORD staticMem) |
DWORD | SetCoreVoltage (DWORD core_voltage) |
DWORD | GetUserData (USERCFG *pUser) |
DWORD | SaveUserData (USERCFG *pUser) |
void | SILGetLibVersion (DWORD *pVerMaj, DWORD *pVerMin, DWORD *pBuild) |
Detailed Description
- Copyright
- Copyright (c) 2012 Toradex AG
- Author:
- kia
- Rev:
- 2101
- Date:
- 2014-03-10 14:27:38 +0100 (Mo, 10 Mrz 2014)
- Target Platforms:
- PXAxxx, T20
#define SIL_VER_BUILD 0 |
#define SIL_VER_MAJ 1 |
#define SIL_VER_MIN 4 |
#define TYPE_NAND 0x02 |
#define TYPE_NOR 0x01 |
Typedef Documentation
typedef struct _PROCESSOR_INFO PROCESSOR_INFO |
Function Documentation
BOOL GetBBTable | ( | BB_RELOC * | reloc, |
DWORD * | numReloc | ||
Get the bad block table
- Parameters
[out] reloc Pointer to Bad Block array [out] numReloc Number of Bad Block records
- Return values
TRUE Success FALSE Failure
BOOL GetBoardSerial | ( | DWORD * | pSerial | ) |
Get the board Serial Number
- Parameters
[out] pSerial Pointer to Serial Number data
- Return values
BOOL GetBoardVersion | ( | HWCFG * | pHWVer | ) |
Get the board Version and Product ID
- Parameters
[out] pHWVer Pointer to Board Version data structure
- Return values
BOOL GetBootloaderInfo | ( | BSPVER * | pBspVer, |
SYSTEMTIME * | pBspDate | ||
Updates the BSP Release Date
- Parameters
[in] pBspVer pointer to BSP version data structure IN/OUT] pBspDate pointer to BSP release date structure
- Return values
DWORD GetFlashSize | ( | DWORD * | pFlashType | ) |
Get the size of the Flash
- Parameters
[out] pFlashType Pointer to Flash Type data
- Returns
- Size of the flash memory [in Bytes]
BOOL GetImageInfo | ( | BSPVER * | pBspVer, |
Check the BSP version and date are valid
- Parameters
[in] pBspVer Pointer to BSP version data structure [in] pBspDate Pointer to the BSP release date
- Return values
BOOL GetMACAddress | ( | BYTE * | pMAC | ) |
Get the MAC Address of the board
- Parameters
[out] pMAC Pointer to MAC Address data
- Return values
DWORD GetMemorySize | ( | void | ) |
Get the RAM memory size
- Parameters
- Returns
- Size of the RAM [in Bytes]
BOOL GetOSVersion | ( | LPOSVERSIONINFO | pOSInfo | ) |
get the Operating System version
- Parameters
[out] pOSInfo Pointer to OS Version Info Structure
- Return values
BOOL GetProcessorInfo | ( | PROCESSOR_INFO * | pPI | ) |
Get the Processor information - see PROCESSOR_INFO definition
- Parameters
[out] pPI Pointer to Processor Info data structure
- Return values
BOOL GetSystemSpeeds | ( | DWORD * | pCpuSpeed, |
DWORD * | pRamSpeed, | ||
DWORD * | pBusSpeed | ||
Get the CPU, RAM and Bus speeds
- Parameters
[out] pCpuSpeed Pointer to CPU Speed [Hz] for PXA, [MHz] for Tegra [out] pRamSpeed Pointer to RAM Speed [Hz] for PXA, [MHz] for Tegra [out] pBusSpeed Pointer to Bus Speed [Hz] for PXA, [MHz] for Tegra
- Return values
TRUE Success. This function always returns TRUE
DWORD GetUserData | ( | USERCFG * | pUser | ) |
Get User Config Data
- Parameters
[out] pUser Pointer to User Config Data Structure
- Returns
- Number of bytes read from flash. User Data is always 256 bytes.
DWORD SaveUserData | ( | USERCFG * | pUser | ) |
Set User Config data
- Parameters
[in] pUser Pointer to User Config Data Structure
- Returns
- Number of bytes written to flash. User Data is always 256 bytes. 0 = failure
DWORD SetCoreVoltage | ( | DWORD | core_voltage | ) |
Set core voltage
- Parameters
[in] core_voltage New core voltage [in mV]
- Returns
- Voltage set [in mV]
- Remarks
- See also Colibri Tweak -> System Clocks
DWORD SetFrequencyPXA270 | ( | DWORD | l, |
DWORD | n, | ||
BOOL | turbo, | ||
BOOL | turbo2, | ||
BOOL | fastBus, | ||
BOOL | altmem, | ||
BOOL | sram2 | ||
Set System Frequencies on PXA270
- Parameters
[in] l Run Mode to 13 Mhz processor Oscillator Ratio [in] n Turbo Mode to Run Mode Ratio [in] turbo Turbo Mode Enable [in] turbo2 Half-Turbo Mode Enable [in] fastbus Fast Bus Mode Enable [in] altmem Memory Controller Clock Alternate Setting Enable [in] sram2 SDRAM Clock Pin 1 Selector
- Return values
0 No Error 1 l<0 | l>30 2 n<0 | n>6
- Remarks
DWORD SetFrequencyPXA3xx | ( | DWORD | l, |
DWORD | n, | ||
DWORD | hsio, | ||
DWORD | sram, | ||
DWORD | staticMem | ||
Set System Frequencies on PXA3xx
- Parameters
[in] l Core PLL Run-Mode-to-Oscillator Ratio [in] n Turbo Mode to Run Mode Ratio [in] hsio System Bus-Clock frequency Select [in] sram SRAM Fequency Select [in] staticMem Static Memory Controller Frequency Select
- Return values
0 No Error 1 l<8 | l>31 2 n<1 | n>2 3 hsio not matched 4 sram not matched 5 staticMem not matched
- Remarks
BOOL SetMACAddress | ( | BYTE * | pMAC | ) |
Set the MAC Address of the board
- Parameters
[in] pMAC Pointer to MAC Address data
- Return values
void SILGetLibVersion | ( | DWORD * | pVerMaj, |
DWORD * | pVerMin, | ||
DWORD * | pBuild | ||
Returns the library Version.
- Parameters
[out] pVerMaj Returns the major version number. Set this parameter to NULL if not required. [out] pVerMin Returns the minor version number. Set this parameter to NULL if not required. [out] pBuild Returns the build number. Set this parameter to NULL if not required.
BOOL SysInfoLibDeInit | ( | void | ) |
Frees the library - call this if you do not need the lbrary anymore.
- Return values
TRUE SysInfoLib is initialized FALSE SysInfoLib is de-initialized
BOOL SysInfoLibInit | ( | void | ) |
Initialise the library - call this before any other functions in tis library
- Return values
