Img Info Lib API
Library to interact with Image Information.
Data Structures
struct  ROMHDRstruct  TOCentrystruct  FILESentrystruct  COPYentrystruct  VERSIONINFOstruct  BSPVER
Macros
#define IMG_VER_MAJ   1
 Library Version.
#define IMG_VER_MIN   4
#define IMG_VER_BUILD   0
#define VI_MAGIC1   0x01234567
#define VI_MAGIC2   0x89abcdef
Typedefs
typedef struct ROMHDR ROMHDR
typedef struct TOCentry TOCentry
typedef struct TOCentryLPTOCentry
typedef struct FILESentry FILESentry
typedef struct FILESentryLPFILESentry
typedef struct COPYentry COPYentry
Functions
BOOL ImgInfoLibInit (void)
BOOL ImgInfoLibDeInit (void)
BOOL FindVersionInfo (BSPVER *pBspVer)
BOOL FindVersionInfoEx (BSPVER *pBspVer, DWORD startAddr, DWORD length)
char * FindVersionString (char *pStr)
BOOL GetTOC (DWORD address, ROMHDR *pTOC, DWORD *pTOCOffset)
DWORD GetIMAGESize (DWORD address)
BOOL FindIMAGE (BOOL bImage, DWORD *pStart, DWORD *pLen)
BOOL GetFlashBootloaderInfo (BSPVER *pBspVer, TCHAR *dateStr)
BOOL GetFlashBootloaderInfoEx (BSPVER *pBspVer, TCHAR *dateStr, DWORD start, DWORD length)
void GetCurrentImageInfo (BSPVER *pBspVer, TCHAR *dateStr)
void IMGGetLibVersion (DWORD *pVerMaj, DWORD *pVerMin, DWORD *pBuild)
Library Version.
Typedef Documentation
typedef struct FILESentry * LPFILESentry
typedef struct TOCentry * LPTOCentry
Function Documentation
BOOL FindIMAGE(BOOL bImage,
  DWORD * pStart,
  DWORD * pLen
Find the image in the Flash
Parameters:
[in]bImageTRUE: Skip First Sector
[out]pStartPointer to start of image
[out]pLenPointer to length of image
Return values:
TRUESuccess
FALSEError
BOOL FindVersionInfo(BSPVERpBspVer)
Finds the BSP Version starting from 0x00 for 256Kb
Parameters:
[out]pBspVerPointer to BSP Version Structure
Return values:
TRUESuccess
FALSEError
BOOL FindVersionInfoEx(BSPVERpBspVer,
  DWORD startAddr,
  DWORD length
Finds the BSP Version, use the supplied start address and length
Parameters:
[in]startAddrStart Address
[in]lengthSearch length
Return values:
TRUESuccess
FALSEError
char* FindVersionString(char * pStr)
Finds the given string
Parameters:
[in]pStrPointer to zero-terminated string to find
Return values:
>0Pointer to last character of the string
NULL(0)String not found
void GetCurrentImageInfo(BSPVERpBspVer,
  TCHAR * dateStr
Get the Current Imae Info
Parameters:
[in]pBspVerPointer to BSP Version
[in]dateStrDate String
BOOL GetFlashBootloaderInfo(BSPVERpBspVer,
  TCHAR * dateStr
Get the Bootloader info from the flash, search the whole of the flash
Parameters:
Return values:
TRUESuccess
FALSEError
BOOL GetFlashBootloaderInfoEx(BSPVERpBspVer,
  TCHAR * dateStr,
  DWORD start,
  DWORD length
Parameters:
[in]startStart Address
[in]lengthLength
Return values:
TRUESuccess
FALSEError
DWORD GetIMAGESize(DWORD address)
Get the Image Size
Parameters:
[in]addressStarting Address
Return values:
ImageSize in bytes
Remarks: We also search at 32KB offset for romhdr (eboot offset
in eboot_formatted.bin)
BOOL GetTOC(DWORD address,
  ROMHDRpTOC,
  DWORD * pTOCOffset
Get the Table of Contents Pointer
Parameters:
[in]addressStarting address
[out]pTOCPointer to TOC
[out]pTOCOffsetPointer to TOC Offset
Return values:
TRUESuccess
FALSEError
void IMGGetLibVersion(DWORD * pVerMaj,
  DWORD * pVerMin,
  DWORD * pBuild
Outputs library version
Parameters:
[out]verMajMajor version number. Set this parameter to NULL if not required
[out]verMinMinor version number. Set this parameter to NULL if not required
[out]buildBuild number. Set this parameter to NULL if not required
BOOL ImgInfoLibDeInit(void  )
Frees the Image Information library
Return values:
TRUESuccess
FALSEError
BOOL ImgInfoLibInit(void  )
Initialise the Image Information Library.
Return values:
TRUESuccess
FALSEError
