Save command
The save command is a CommandPrompt command. It adds an additional config item to the Config Block. If there is an additional config item, the Bootloader will use this instead of the default configuration.
Syntax: To add an additional configuration entry for a specific item type: save<item>
Example: Adding an additional configuration entry for the dbg item.
save dbg
