Cloud Rds Lib API
Contains function declarations to be used to access MySQL Server. Target Modules are Colibri Modules [PXAxxx, Tegra T20, Tegra T30], WinCE 6.0 / 7.0 . More...
Data Structures
struct  mysql
Macros
#define MYSQL_ERROR_STRING_LENGTH   256
#define MYSQL_INSTANCE_ENDPOINT_LENGTH   64
#define MYSQL_USER_NAME_LENGTH   64
#define MYSQL_USER_PASSWORD_LENGTH   64
#define MYSQL_QUERY_STRING_LENGTH   256
#define FILENAME_BUFFER_SIZE   128
#define DATA_SEND_BUFFER_SIZE   1024
#define DATA_RECEIVE_BUFFER_SIZE   1024
Typedefs
typedef struct mysqlMYSQL
Functions
BOOL MySqlOpen (MYSQL *mysqlAccount, const CHAR *sqlInstanceEndpoint, const CHAR *sqlUserName, const CHAR *sqlUserPassword)
BOOL MySqlConnect (MYSQL mysqlAccount, WORD mysqlPortNumber)
BOOL MySqlConnectWithSsl (MYSQL mysqlAccount, WORD mysqlPortNumber)
BOOL MySqlRowQuery (MYSQL mysqlAccount, const CHAR *mysqlQuery, const CHAR *resultFilePath, DWORD *columnsInTable)
BOOL MySqlClose (MYSQL *mysqlAccount)
BOOL MySqlQuit (MYSQL mysqlAccount)
BOOL MySqlInitDb (MYSQL mysqlAccount, const CHAR *schemaName)
BOOL MySqlListFields (MYSQL mysqlAccount, const CHAR *tableName, const CHAR *resultFilePath, DWORD *columnsInTable)
BOOL MySqlCreateDb (MYSQL mysqlAccount, const CHAR *createDbStatement)
BOOL MySqlDropDb (MYSQL mysqlAccount, const CHAR *schemaName)
BOOL MySqlPing (MYSQL mysqlAccount)
BOOL MySqlUpdateQuery (MYSQL mysqlAccount, const CHAR *updateQuery)
BOOL MySqlInsertQuery (MYSQL mysqlAccount, const CHAR *insertQuery)
BOOL MySqlDeleteQuery (MYSQL mysqlAccount, const CHAR *deleteQuery)
DWORD MySqlAffectedRows (MYSQL mysqlAccount)
BOOL MySqlAlterQuery (MYSQL mysqlAccount, const CHAR *alterQuery)
BOOL MySqlGetNumberOfRows (MYSQL mysqlAccount, const CHAR *tableName, DWORD *numberOfRows)
BOOL MySqlListTables (MYSQL mysqlAccount, const CHAR *dbInstanceName, const CHAR *filePath)
void MySqlClearError (MYSQL mysqlAccount)
BOOL MySqlCreateViewQuery (MYSQL mysqlAccount, const CHAR *viewQuery)
BOOL MySqlPrepareStatementQuery (MYSQL mysqlAccount, const CHAR *prepareQuery, DWORD *statementId, DWORD *numberOfParamters)
BOOL MySqlPrepareSendLongData (MYSQL mysqlAccount, DWORD statementId, DWORD parameterId, const CHAR *dataForPrepareQuery)
BOOL MySqlStatementExecute (MYSQL mysqlAccount, DWORD statementId, DWORD numberOfParameters, DWORD optionFlags)
BOOL MySqlPrepareStatementClose (MYSQL mysqlAccount, DWORD statementId)
BOOL MySqlPrepareStatementReset (MYSQL mysqlAccount, DWORD statementId)
BOOL MySqlSetMultiStatementOption (MYSQL mysqlAccount, BOOL multiStatementOn)
BOOL MySqlStatementFetch (MYSQL mysqlAccount, DWORD statementId)
Detailed Description
Contains function declarations to be used to access MySQL Server. Target Modules are Colibri Modules [PXAxxx, Tegra T20, Tergra T30], WinCE 6.0 / 7.0 .
Author:
Rev:
Date:
2014-01-08 10:00:00 +0530 (Wed, 08 Jan 2014)
Function Documentation
DWORD MySqlAffectedRows(MYSQL mysqlAccount)
Returns the number of rows changed, deleted, or inserted
Parameters
[in]mysqlAccountHandle returned by call to MySqlOpen()
Return values
Numberof rows affected Contains valid value only after successful calls to MySqlUpdate(), MySqlInsert() or MySqlDelete()
BOOL MySqlAlterQuery(MYSQL mysqlAccount,
  const CHAR * alterQuery
Add, Delete or Modify columns in the table
Parameters
[in]alterQueryMySQL ALTER query statement For example: "ALTER TABLE mysqldb.TestDbTable ADD Column3 int" where mysqldb is the schema/database name and TestDbTable is the table name
Return values
TRUESuccess
FALSESee WSAGetLastError() and GetLastError()
void MySqlClearError(MYSQL mysqlAccount)
Clears the MySQL error number and error string
Parameters
Return values
BOOL MySqlClose(MYSQLmysqlAccount)
Close the handle for the MySQL connection
Parameters
Return values
TRUESuccess
BOOL MySqlConnect(MYSQL mysqlAccount,
Opens a connection to the Amazon RDS MySQL instance
Parameters
[in]mysqlPortNumberPort number on which to communicate with the Amazon RDS MySQL instance If specified as 0, default MySQL port number of 3306 will be used
Return values
TRUESuccess
FALSESee GetLastError() and WSAGetLastError()
BOOL MySqlConnectWithSsl(MYSQL mysqlAccount,
Open a conenction to the Amazon RDS MySQL instance using SSL
Parameters
Return values
TRUESuccess
BOOL MySqlCreateDb(MYSQL mysqlAccount,
  const CHAR * createDbStatement
Create a new schema/database
Parameters
[in]createDbStatementMySQL CREATE_DATABASE statement Example: "CREATE TABLE mysqldb.TestDbTable(Column1 int primary key auto_increment, Column2 int)" where "mysqldb" is the schema/database name and "TestDbTable" is the table name
Return values
TRUESuccess
BOOL MySqlCreateViewQuery(MYSQL mysqlAccount,
  const CHAR * viewQuery
Create views for the database table
Parameters
[in]viewQueryMySQL View query statement Example: CREATE VIEW view_name AS SELECT column_name(s) FROM table_name WHERE condition
Return values
TRUESuccess
FALSESee WSAGetLastError() and GetLastError() To be implemented
BOOL MySqlDeleteQuery(MYSQL mysqlAccount,
  const CHAR * deleteQuery
Delete data in the table
Parameters
[in]deleteQueryMySQL DELETE query statement For example: "DELETE FROM mysqldb.TestDbTable WHERE Column1 = 900" where mysqldb is the schema/database name and TestDbTable is the table name
Return values
TRUESuccess
BOOL MySqlDropDb(MYSQL mysqlAccount,
  const CHAR * schemaName
Drop a schema/database
Parameters
[in]schemaNameName of the schema/database to drop Example: "mysqldb.TestDbTable" where "mysqldb" is the schema/database name and "TestDbTable" is the table name
Return values
TRUESuccess
BOOL MySqlGetNumberOfRows(MYSQL mysqlAccount,
  const CHAR * tableName,
  DWORD * numberOfRows
Get the number of records in the table
Parameters
[in]tableNameTable name for which number of records has to be retrieved Example: "mysqldb.TestDbTable" where "mysqldb" is the schema/database name and "TestDbTable" is the table name
[out]numberOfRowsNumber of records in the table
Return values
TRUESuccess
BOOL MySqlInitDb(MYSQL mysqlAccount,
Change the default schema of the connection
Parameters
[in]schemaNameName of the schema to change to
Return values
TRUESuccess
BOOL MySqlInsertQuery(MYSQL mysqlAccount,
  const CHAR * insertQuery
Insert data in the table
Parameters
[in]insertQueryMySQL INSERT query statement For example: "INSERT INTO mysqldb.TestDbTable (Column1, Column2) VALUES(900, 1000)" where mysqldb is the schema/database name and TestDbTable is the table name
Return values
TRUESuccess
BOOL MySqlListFields(MYSQL mysqlAccount,
  const CHAR * resultFilePath,
  DWORD * columnsInTable
Get the column definitions of a table
Parameters
[in]tableNameTable name for which column definition has to be retrieved Example: "mysqldb.TestDbTable" where "mysqldb" is the schema/database name and "TestDbTable" is the table name
[in]resultFilePathPointer to the local file path string in which result will be stored
[out]columnsInTableNumber of columns in the table
Return values
TRUESuccess
FALSESee WSAGetLastError() and GetLastError() Data will be in the following format: Field Type Null Key Default Extra
BOOL MySqlListTables(MYSQL mysqlAccount,
  const CHAR * dbInstanceName,
  const CHAR * filePath
List tables in the database
Parameters
[in]dbInstanceNameName of the MySQL database instance
[in]filePathPointer to the local file path string in which result will be stored
Return values
TRUESuccess
BOOL MySqlOpen(MYSQLmysqlAccount,
  const CHAR * sqlInstanceEndpoint,
  const CHAR * sqlUserName,
  const CHAR * sqlUserPassword
Opens a handle for the MySQL connection
Parameters
[out]mysqlAccountAmazon RDS MySQL instance account handle
[in]sqlInstanceEndpointEndpoint address of the Amazon RDS MySQL instance
[in]sqlUserNameUser name of the Amazon RDS MySQL instance
[in]sqlUserPasswordPassword for the Amazon RDS MySQL instance
Return values
TRUESuccess
BOOL MySqlPing(MYSQL mysqlAccount)
Check if the server connection is alive
Parameters
Return values
TRUESuccess
BOOL MySqlPrepareSendLongData(MYSQL mysqlAccount,
  DWORD statementId,
  DWORD parameterId,
  const CHAR * dataForPrepareQuery
Send data for a prepared statement
Parameters
[in]statementIdStatement Id returned from a previous call to MySqlPrepareQuery()
[in]parameterIdParameter Id for the data
[in]dataForPrepareQueryData for the prepare query
Return values
TRUESuccess
FALSESee WSAGetLastError() and GetLastError() Must be called before MySqlPrepareStatementExecute() To be implemented
BOOL MySqlPrepareStatementClose(MYSQL mysqlAccount,
  DWORD statementId
Deallocates a prepare statement query
Parameters
[in]statementIdStatement Id returned by call to MySqlPrepareQuery()
Return values
TRUESuccess
BOOL MySqlPrepareStatementQuery(MYSQL mysqlAccount,
  const CHAR * prepareQuery,
  DWORD * statementId,
  DWORD * numberOfParamters
Create a prepared statement
Parameters
[in]preparQueryMySQL prepare query statement
[out]statementIdStatement ID use to identify the prepare statement
[out]numberOfParametersNumber of Parameters
Return values
TRUESuccess
BOOL MySqlPrepareStatementReset(MYSQL mysqlAccount,
  DWORD statementId
Reset the data of a prepared statement which was accumulated with MySqlPrepareSendLongData()
Parameters
Return values
TRUESuccess
BOOL MySqlQuit(MYSQL mysqlAccount)
Close the connection to the Amazon RDS MySQL instance
Parameters
Return values
TRUESuccess
BOOL MySqlRowQuery(MYSQL mysqlAccount,
  const CHAR * mysqlQuery,
Query the rows of Amazon RDS MySQL instance
Parameters
[in]mysqlQueryMySQL SELECT Query statement For example: "SELECT * FROM mysqldb.TestDbTable" where mysqldb is the schema/database name and TestDbTable is the MySQL table name
[in]resultFilePathPointer to the local file path string in which result of MySQL query will be stored
Return values
TRUESuccess
BOOL MySqlSetMultiStatementOption(MYSQL mysqlAccount,
Set Multi statement operation
Parameters
[in]multiStatementOnTRUE: Multi statements ON, FALSE: Multi statements OFF
Return values
TRUESuccess
BOOL MySqlStatementExecute(MYSQL mysqlAccount,
  DWORD statementId,
  DWORD optionFlags
Execute a statement query
Parameters
[in]numberOfParametersNumber of parameters returned by call to MySqlPrepareQuery()
[in]optionFlagsOption flags for prepare statment execution
Return values
TRUESuccess
BOOL MySqlStatementFetch(MYSQL mysqlAccount,
  DWORD statementId
Fetch a row from a existing resultset after a COM_STMT_EXECUTE.
Parameters
[in]statementIdStatement Id of a stored procedure
Return values
TRUESuccess
BOOL MySqlUpdateQuery(MYSQL mysqlAccount,
  const CHAR * updateQuery
Update data in the table
Parameters
[in]updateQueryMySQL UPDATE query statement For example: "UPDATE mysqldb.TestDbTable SET Column2 = 1001 WHERE Column1 = 900" where mysqldb is the schema/database name and TestDbTable is the table name
Return values
TRUESuccess
