MFC / ATL
MFC and ATL are supported. However, there is currently a Microsoft bug which manifests while running applications using MFC or ATL on a Windows CE 7 multi-core system. To avoid problems, you need to configure the linker for Windows CE 6.
- Go to "Project -> Properties"
- Now choose: Configuration "Properties -> Linker -> Commandline"
- If there is already a "/Subsystem" parameter delete it
- Add the following string: /subsystem:windowsce,6.00
