Cloud Sns Lib API
Contains function declarations to be used to access AWS Cloud Sns Services Colibri Modules [PXAxxx, Tegra T20], WinCE 6.0 / 7.0 Number of Topics are restricted to 100, number of subscriptions per Topic are limited to 100. More...
Macros | |
| #define | AWS_SNS_ACCESS_ID_MAX_LENGTH 20 |
| AWS Account ID string Length. | |
| #define | AWS_SNS_SECRET_KEY_MAX_LENGTH 40 |
| AWS Account Secret Kay String Length. | |
| #define | AWS_SNS_OWNER_ID_MAX_LENGTH 12 |
| AWS Account Owner ID String Length. | |
| #define | SNS_TOPIC_NAME_MAX_LENGTH 256 |
| Maximum number of characters allowed in Topic Name. | |
| #define | SNS_DISPLAY_NAME_MAX_LENGTH 100 |
| Maximum number of characters allowed in Topic's Display Name. | |
| #define | SNS_MAX_TIME_STRING_LENGTH 24 |
| AWS Sns Formatted Time String Length. | |
| #define | AWS_SNS_SIGNATURE_HASH_LEN 32 |
| HMAC-SHA2 HASH Length. | |
| #define | AWS_SNS_SIGNATURE_STRING_LEN 44 |
| HMAC-SHA2 Signature String Length. | |
| #define | AWS_SNS_MESSAGE_SIZE_MAX (32 * 1024) |
| Maximum allowed message length 32 KB (Applicable to SnsPublish) | |
| #define | AWS_SNS_SUBJECT_MAX (100) |
| Maximum number of characters allowed in subject (Applicable to SnsPublish) | |
| #define | SNS_LIST_TOPIC_RECEIVE_CHUNK (32 * 1024) |
| Buffer Size used when receiving list of Topics. | |
| #define | SNS_LIST_SUBSCRIPTION_RECEIVE_CHUNK (32 * 1024) |
| Buffer Size used when receiving list of Subscriptions. | |
| #define | PROTOCOL_TYPE_HTTP 1 |
| http Protocol | |
| #define | PROTOCOL_TYPE_HTTPS 2 |
| https Protocol | |
| #define | PROTOCOL_TYPE_EMAIL 3 |
| email Protocol | |
| #define | PROTOCOL_TYPE_EMAIL_JSON 4 |
| email-json Protocol | |
| #define | PROTOCOL_TYPE_SMS 5 |
| sms Protocol | |
| #define | PROTOCOL_TYPE_SQS 6 |
| sqs Protocol | |
| #define | ATTRIBUTE_TYPE_POLICY 1 |
| Attribute Type Selection Policy. | |
| #define | ATTRIBUTE_TYPE_DISPLAYNAME 2 |
| Attribute Type Selection Display Name. | |
| #define | ATTRIBUTE_TYPE_DELIVERYPOLICY 3 |
| Attribute Type Selection Delivery Policy. | |
| #define | SNS_HANDLE_MEMORY_ALLOCATION_SIZE (7 * 4) |
| #define | SNS_HTTP_RESPONSE_DATA_BUFFER_SMALL (1 * 1024) |
| #define | SNS_HTTP_RESPONSE_DATA_BUFFER_LARGE (3 * 1024) |
| #define | SNS_HTTP_ARGUMENT_BUFFER_SMALL (2 * 1024) |
| #define | SNS_STRING_TO_SIGN_BUFFER_SMALL (2 * 1024) |
| #define | URL_ENCODED_TOPIC_NAME_BUFFER 1024 |
| #define | URL_ENCODED_TOPIC_ARN_BUFFER 1024 |
| #define | URL_ENCODED_SUB_ARN_BUFFER 1024 |
| #define | URL_ENCODED_ENDPOINT_BUFFER 1024 |
| #define | URL_ENCODED_SUBJECT_BUFFER 512 |
| #define | URL_ENCODED_ATTRIBUTE_VALUE_BUFFER 512 |
| #define | PROTOCOL_STRING_LENGTH 10 |
| #define | ATTRIBUTE_VALUE_BUFFER_SIZE 256 |
Functions | |
| BOOL | SnsOpenTopic (char *accessID, char *secretKey, char *ownerId, char *path, char *topicName, char *displayName, HSNS *snsTopicHandle) |
| BOOL | SnsCloseTopic (HSNS *snsTopicHandle) |
| BOOL | SnsCreateTopic (HSNS snsTopicHandle) |
| BOOL | SnsPublish (HSNS snsTopicHandle, const char *subject, const char *message) |
| BOOL | SnsDeleteTopic (HSNS snsTopicHandle) |
| BOOL | SnsSubscribe (HSNS snsTopicHandle, char *endPoint, BYTE protocolType) |
| BOOL | SnsListTopics (HSNS snsTopicHandle, char *filePath) |
| BOOL | SnsUnsubscribe (HSNS snsTopicHandle, char *subArn) |
| BOOL | SnsListSubscriptions (HSNS snsTopicHandle, char *filePath) |
| BOOL | SnsFindTopic (const char *filePath, char *dataOut, DWORD dataOutSize, DWORD *pointerToNextTopic, DWORD fileSize) |
| BOOL | SnsFindSubscriptions (const char *filePath, char *dataOut, DWORD dataOutSize, DWORD *pointerToNextSubscriptionByTopic, DWORD fileSize) |
| BOOL | SnsGetSubscriptionAttribtues (HSNS snsTopicHandle, char *subArn, char *dataOut, DWORD dataOutSize) |
| BOOL | SnsGetTopicAttributes (HSNS snsTopicHandle, char *dataOut, DWORD dataOutSize) |
| BOOL | SnsSetTopicAttributes (HSNS snsTopicHandle, BYTE attributeType, char *attributeValue) |
Detailed Description
- Copyright
- Copyright (c) 2012 Toradex AG [Software License Agreement]
- Author:
- agp
- Version
- Rev:
- 1154
- Date
- Date:
- 2012-11-08 19:56:19 +0530 (Thu, 08 Nov 2012)
Function Documentation
| BOOL SnsCloseTopic | ( | HSNS * | snsTopicHandle | ) |
Deletes already created Sns Topic Handle
- Parameters
[in] snsTopicHandle Handle returned by call to SnsTopicOpen()
- Return values
TRUE Success FALSE See GetLastError()
| BOOL SnsCreateTopic | ( | HSNS | snsTopicHandle | ) |
Creates new Sns Topic
- Parameters
- Return values
| BOOL SnsDeleteTopic | ( | HSNS | snsTopicHandle | ) |
Deletes already existing Sns Topic
- Parameters
- Return values
| BOOL SnsFindSubscriptions | ( | const char * | filePath, |
| char * | dataOut, | ||
| DWORD | dataOutSize, | ||
| DWORD * | pointerToNextSubscriptionByTopic, | ||
| DWORD | fileSize | ||
Finds Subscription details by Topic from list of subscriptionsByTopic stored in a local file
The file must be initialized by calling SnsListSubscriptionsByTopic()
- Parameters
[in] filePath File path in which list of subscription exists [out] dataOut Pointer to the output string containing subscription details, user need to allocate memory [in] dataOutSize Number of bytes allocated for dataOut [in,out] pointerToNextSubscriptionByTopic Pointer to next Subscription details from list data, to find 1st Subscription by topic Detail, put NULL [in] fileSize Size of the file in bytes
- Return values
| BOOL SnsFindTopic | ( | const char * | filePath, |
| DWORD * | pointerToNextTopic, | ||
Finds Topic Details from list of Topics stored in a local file
The file must be initialized by calling SnsListTopics()
- Parameters
[in] filePath File path in which list of subscription exists [out] dataOut Pointer to the output string containing Topic details, user need to allocate memory [in] dataOutSize Number of bytes allocated for dataOut [in,out] pointerToNextTopic Pointer to next Topic details from list data, to find 1st topic details, put NULL. [in] fileSize Size of the file in bytes
- Return values
| BOOL SnsGetSubscriptionAttribtues | ( | HSNS | snsTopicHandle, |
| char * | subArn, | ||
| DWORD | dataOutSize | ||
Gets Subscription Attributes
- Parameters
[in] snsTopicHandle Handle returned by call to SnsTopicOpen() [in] subArn Subscription Arn String [out] dataOut Pointer to the output string containing subscription attributes details, user need to allocate memory [in] dataOutSize Number of bytes allocated for dataOut
- Return values
| BOOL SnsGetTopicAttributes | ( | HSNS | snsTopicHandle, |
Gets Topic Attributes of Sns Topic
- Parameters
[in] snsTopicHandle Handle returned by call to SnsTopicOpen() [out] dataOut Pointer to the output string containing TopicAttribute details, user need to allocate memory [in] dataOutSize Number of bytes allocated for dataOut
- Return values
| BOOL SnsListSubscriptions | ( | HSNS | snsTopicHandle, |
| char * | filePath | ||
Lists Subscriptions by topic in an Sns Account, for a particular region (max 100)
Subscriptions by Topic are stored into a local file
- Parameters
[in] snsTopicHandle Handle returned by call to SnsTopicOpen() [in] filePath File in which list of Subscriptions by topics will be saved, user need to delete already existing file,
else list data will be appended in the same file
- Return values
TRUE Success FALSE See GetLastError() Number of Topics are restricted to 100, number of subscriptions per Topic are limited to 100
| BOOL SnsListTopics | ( | HSNS | snsTopicHandle, |
Lists topics in an Sns Account, for a particular region (max 100)
Topics are stored into a local file
- Parameters
[in] snsTopicHandle Handle returned by call to SnsTopicOpen() [in] filePath File in which list of topics will be saved, user need to delete already existing file,
- Return values
| BOOL SnsOpenTopic | ( | char * | accessID, |
| char * | secretKey, | ||
| char * | ownerId, | ||
| char * | path, | ||
| char * | topicName, | ||
| char * | displayName, | ||
| HSNS * | snsTopicHandle | ||
Opens handle for Sns topic, the returned snsTopicHandle is required as an input parameter to every Sns function call
- Parameters
[in] accessID AWS Access ID [20 Characters] [in] secretKey AWS Secret Key [40 Characters] [in] ownerId AWS Owner ID [12 Characters] [in] path AWS Sns path [in] topicName Topic names must be constructed using only uppercase and lowercase ASCII letters,
numbers, underscore, hyphens and must be between 1 and 256 characters long[in] displayName [OPTIONAL] if not NULL, Display names must be constructed using only uppercase/lowercase ASCII letters,
numbers, underscore, hyphens and must be between 1 and 100 characters long[out] snsTopicHandle Structure to hold various sns related parameters.
- Return values
| BOOL SnsPublish | ( | HSNS | snsTopicHandle, |
| const char * | subject, | ||
| const char * | message | ||
Publishes/Sends a message to all the subscribed endpoints of a topic. When a messageId is returned,
the message has been saved and Amazon Sns will attempt to deliver it to the topic subscribers shortly
The format of the outgoing message to each subscribed endpoint depends on the notification protocol selected
- Parameters
[in] snsTopicHandle Handle returned by call to SnsTopicOpen() [in] subject Optional parameter to be used as the "Subject" line, when the message is delivered to e-mail endpoints, max 100 ASCII characters [in] message The message you want to send to the topic. Maximum length is 32 x 1024 characters
- Return values
| BOOL SnsSetTopicAttributes | ( | HSNS | snsTopicHandle, |
| BYTE | attributeType, | ||
| char * | attributeValue | ||
Sets Topic Attributes
- Parameters
[in] snsTopicHandle Handle returned by call to SnsTopicOpen() [in] attributeType [1] - Policy,
[2] - DisplayName,
[3] - DeliveryPolicy[in] attributeValue String containing respective attribute value
- Return values
TRUE Success FALSE See GetLastError() only attributes = 2 (DisplayName) is working
| BOOL SnsSubscribe | ( | HSNS | snsTopicHandle, |
| char * | endPoint, | ||
| BYTE | protocolType | ||
Subscribes an endpoint to a topic
- Parameters
[in] snsTopicHandle Handle returned by call to SnsTopicOpen() [in] endPoint URL "http://", URL "https://" , Email ID, Phone number for SMS, SQS: ARN of an Amazon SQS queue, etc [in] protocolType Valid Values can be from 1 to 6,
[1] - "http",
[2] - "https",
[3] - "email",
[4] - "email-json",
[5] - "sms",
[6] - "sqs"
- Return values
| BOOL SnsUnsubscribe | ( | HSNS | snsTopicHandle, |
| char * | subArn | ||
Unsubscribes an endpoint from its subscription
- Parameters
- Return values
