Windows CE Library - Co-Processor Interface Library (CoProcLib)
Description
This library Interfaces to the Co-Processor registers for Module & Processor identification, Clock and Power modes.
Current Version
V2.2
Application Notes
CoProcLib contains a function (getPROCID()) to query the Processor Type (PXA270, PXA300, PXA310, PXA320, T20 & T30).
CoProclib contains a function (getModuleFamily()) to query the Module Family (Apalis, Colibri).
CoProcLib also contains functions to query and set Clock, Power & L2 Cache Modes.
Library API
Other Resources
Revision History
Date | Rev | Change Notes |
11/03/2014 | V2.2 | Add missing functions to DLL: GetSoCType() and getModuleFamily() Add functions to enable/disable/query SWP assembler instruction support Added CoprocLibDemo application |
24/06/2103 | V2.1 | Added support for Colibri PXA300XT |
17/06/2013 | V2.0.1 | Updated to work with Apalis T30 |
