Windows CE Library - Interrupt Service Routine Library (INTLib)
Description
This library manages installable Interrupt Service Routines.
Current Version
V2.6
Application Notes
INTLib provides for level-triggered and edge triggered interrupts.
Library API
Other Resources
Revision History
| Date | Rev | Change Notes |
| 29/06/2015 | V2.6 | Fix memory leak in InterruptInitializeCompat() for Tegra |
| 23/09/2013 | V2.5.1 | Minor Code optimizations |
| 23/09/2013 | V2.4 | Change default SDK to Colibri600 / Replace OAL_INTR_FORCE_STATIC by OAL_INTR_TRANSLATE and added some fixes to allow reusing the same SysIntr IDs. |
| 12/08/2013 | V2.3.2 | Changed scope of internal variables to be internal only |
| 24/06/2013 | V2.3.1 | Fixed __GetUserKData() link error under Windows CE 5 |
