ADC Lib API
Library to support ADC interfacing. More...
Macros
##define CODEC_UNKNOWN 0 #define CODEC_UCB1400 1 #define CODEC_WM9713 2 #define CODEC_WM9715 3 #define CODEC_SGTL5000 4 #define ADC_VER_MAJ 2 Version Info. More...
#define ADC_VER_MIN 3 #define ADC_VER_BUILD 0
Functions | |
| BOOL | Ac97Init (void) |
| BOOL | Ac97DeInit (void) |
| void | ADCGetLibVersion (DWORD *pVerMaj, DWORD *pVerMin, DWORD *pBuild) |
| DWORD | getCodecType (void) |
| BOOL | ReadADCChannel (BYTE channel, DWORD *value, DWORD samples) |
| DWORD | MicrovoltsPerLsb (BYTE channel) |
| DWORD | ReadTouch (BYTE mode, DWORD filter) |
| BOOL | Ac97Write (UINT16 offset, UINT16 data) |
| BOOL | Ac97Read (UINT16 offset, UINT16 *pdata) |
Detailed Description
- Copyright
- Copyright (c) 2012 Toradex AG
- Author
- samuel.bissig
- Rev
- 2688
- Date
- 2015-03-09 13:36:34 +0100 (Mo, 09 Mrz 2015)
- Target Platforms:
- PXAxxx, T20
| #define ADC_VER_BUILD 0 |
| #define ADC_VER_MAJ 2 |
Version Info.
| #define ADC_VER_MIN 3 |
| #define CODEC_SGTL5000 4 |
| #define CODEC_UCB1400 1 |
| #define CODEC_UNKNOWN 0 |
| #define CODEC_WM9713 2 |
| #define CODEC_WM9715 3 |
Function Documentation
| BOOL Ac97DeInit | ( | void | ) |
Deinitializes the AC97 interface.
- Return values
TRUE Success. FALSE Error.
| BOOL Ac97Init | ( | void | ) |
Initializes the AC97 interface.
- Return values
| BOOL Ac97Read | ( | UINT16 | offset, |
| UINT16 * | pdata | ||
Directly reads an AC97 register.
- Parameters
[in] offset Register address. [out] pdata 16-bit value read from the register.
- Return values
| BOOL Ac97Write | ( | UINT16 | offset, |
| UINT16 | data | ||
Directly writes to an AC97 register
- Parameters
[in] offset Register address. [in] data 16-bit value to write into the register.
- Return values
| void ADCGetLibVersion | ( | DWORD * | pVerMaj, |
| DWORD * | pVerMin, | ||
| DWORD * | pBuild | ||
Reads the library Version.
- Parameters
[out] pVerMaj Major version number. [out] pVerMin Minor version number. [out] pBuild Build number.
| DWORD getCodecType | ( | void | ) |
Reads which codec is installed on the current Colibri module.
- Return values
0 Codec unknown. 1 UCB1400. 2 WM9713. 3 WM9715. 4 SGTL5000
| DWORD MicrovoltsPerLsb | ( | BYTE | channel | ) |
Gets Converstion constant Microvolts per LSB. This can be different for each ADC and even for each channel.
- Parameters
[in] channel ADC channel number (0..3)
- Return values
(7500000/1024) Conversion constant Microvolts per ADC LSB. (3300000*3/4096) Conversion constant Microvolts per ADC LSB. (3300000 /4096) Conversion constant Microvolts per ADC LSB. 0 Error.
| BOOL ReadADCChannel | ( | BYTE | channel, |
| DWORD * | value, | ||
| DWORD | samples | ||
Reads one ADC channel from Colibri's audio codec.
- Parameters
[in] channel ADC channel number (0..3) [in] samples number of samples that should be taken, they will be summed up [out] value raw ADC value, if sampels>1, value is the SUM of all measurements.
- Return values
| DWORD ReadTouch | ( | BYTE | mode, |
| DWORD | filter | ||
Reads one value from the touch controller
- Parameters
[in] mode X or Y axis measurement. [in] samples Number of samples required.
- Return values
value Position value. FALSE No access. -1 Error.
Remarks: Only the UCB1400 codec is currently supported.
