Windows CE Library - SPI Library (SPILib)
Description
This library manages the SPI interfaces via polling
Current Version
V5.4
Application Notes
SPILib supports up to 6 SPI ports on Colibri and Apalis modules.
The SPILib can be used in PIO-mode or DMA mode. PIO mode is more efficient for transfers < 32 SPI Words.
In SPI slave mode, data can easily get lost if packets are larger than FIFO size (32 frames on T20/T30). Use DMA mode instead.
Library API
Other Resources
Revision History
| Date | Rev | Change Notes |
| 29/06/2015 | V5.4 | Fix default pin configuration for PXA300. Implemented automatic default pin selection for all SPI channels on Colibri T20/T30 and Apalis T30. Added code to detect and resolve conflicting AltFn settings on multiple pins (Tegra). Added configuration options for Tegra (wait method, chip select number/behavior, packed mode). Support all 6 SPI channels on T30. This is a requirement for CAN1 on Apalis T30. Replace printf debug messages with regular debug output. Improve stability of SPI communication on Tegra. Performance may be slightly degraded. |
| 30/10/2014 | V5.3 | Fix issue on T20/T30 modules: Small SPI transfers using DMA caused the application to freeze. Fix issue on T20/T30 modules: SPI transfers using DMA caused the application to freeze, if transfer size was not a multiple of 4. |
| 27/05/2014 | V5.2 | Non-standard SPI pin configurations can now be defined as GPIO numbers instead of SODIMM pins. This is to support on-module SPI channels, e.g. for the Apalis on-module CAN controllers Adjust default SPI pin configurations for Apalis |
| 15/04/2014 | V5.1 | Add TegSpiSetWaitMethod() to choose between interrput-driven and busyLoop waiting Use DMA-like SPI control method even in non-DMA mode to prevent possible data loss of received data. Remove deprecated functions TegWriteSPIUnpacdked() and TegReadSPIUnpacked() Fix issue that caused a data abort when calling SPIInit() the 2nd time |
| 11/03/2014 | V5.0 | Fix bit rate calculation Pre-allocate memory for DMA, instead of allocating it for each transfer Performance improvements Fix pin initialization |
| 23/09/2013 | V4.1 | Change default SDK to Colibri600 / Added support for T30's SPI5 and SPI6 |
| 12/08/2013 | V4.0.1 | Improved performance of SPIReadWritePolling(), SPIReadPolling() and SPIWritePolling() on Tegra processors |
