Map Reg Lib API
Library to support Register Mapping. More...
Data Structures
struct MEM_T Struct for physical and virtual addresses - useful for DMA operations)Macros | |
#define | MRL_VER_MAJ 1 |
#define | MRL_VER_MIN 3 |
#define | MRL_VER_BUILD 0 |
#define | PAGE_SIZE 4096 |
#define | UnMapMemory UnMapRegister |
Functions | |
LPVOID | AllocPhysMem (DWORD cbSize, DWORD fdwProtect, DWORD dwAlignmentMask, DWORD dwFlags, PULONG pPhysicalAddress) |
BOOL | FreePhysMem (LPVOID lpvAddress) |
BOOL | VirtualCopy (LPVOID lpvDest, LPVOID lpvSrc, DWORD cbSize, DWORD fdwProtect) |
BOOL | VirtualSetAttributes (LPVOID lpvAddress, DWORD cbSize, DWORD dwNewFlags, DWORD dwMask, LPDWORD lpdwOldFlags) |
LPVOID | CreateStaticMapping (DWORD dwPhysBase, DWORD dwSize) |
void * | MapRegister (DWORD pa) |
void * | MapMemory (DWORD pa, DWORD size) |
void | UnMapRegister (volatile void *pRegs) |
LPVOID | AllocPhysMemCompat (DWORD cbSize, DWORD fdwProtect, DWORD dwAlignmentMask, DWORD dwFlags, PULONG pPhysicalAddress) |
BOOL | FreePhysMemCompat (LPVOID lpvAddress) |
BOOL | VirtualCopyCompat (LPVOID lpvDest, LPVOID lpvSrc, DWORD cbSize, DWORD fdwProtect) |
BOOL | LockPagesCompat (LPVOID lpvAddress, DWORD cbSize, PDWORD pPFNs, int fOptions) |
BOOL | VirtualSetAttributesCompat (LPVOID lpvAddress, DWORD cbSize, DWORD dwNewFlags, DWORD dwMask, LPDWORD lpdwOldFlags) |
void * | OALPAtoVA (UINT32 pa, BOOL cached) |
void | MRLGetLibVersion (DWORD *pVerMaj, DWORD *pVerMin, DWORD *pBuild) |
Detailed Description
- Copyright
- Copyright (c) 2013 Toradex AG
- Author:
- kia
- Rev:
- 2101
- Date:
- 2014-03-10 14:27:38 +0100 (Mo, 10 Mrz 2014)
- Target Platforms:
- Colibri PXAxxx, T20 & T30, Apalis T30
#define MRL_VER_BUILD 0 |
#define MRL_VER_MAJ 1 |
#define MRL_VER_MIN 3 |
#define PAGE_SIZE 4096 |
#define UnMapMemory UnMapRegister |
Function Documentation
LPVOID AllocPhysMem | ( | DWORD | cbSize, |
DWORD | fdwProtect, | ||
DWORD | dwAlignmentMask, | ||
DWORD | dwFlags, | ||
PULONG | pPhysicalAddress | ||
LPVOID AllocPhysMemCompat | ( | DWORD | cbSize, |
Win CE 6.0 and 5.0 compatible version of AllocPhysMem()
- Parameters
[in] cbSize Number of bytes to allocate [in] fdwProtect Specifies the protection desired [in] dwAlignmentmask Bit mask describing the byte alignment [in] dwFlags Reserved, set to 0 [in] pPhysicalAddress Physical address
- Return values
0 Error >0 Virtual address
LPVOID CreateStaticMapping | ( | DWORD | dwPhysBase, |
DWORD | dwSize | ||
BOOL FreePhysMem | ( | LPVOID | lpvAddress | ) |
BOOL FreePhysMemCompat | ( | LPVOID | lpvAddress | ) |
Win CE 6.0 and 5.0 compatible version of FreePhysMem()
- Parameters
[in] lpvAddress Virtual Address
- Return values
FALSE,: Failure, TRUE: Success
BOOL LockPagesCompat | ( | LPVOID | lpvAddress, |
DWORD | cbSize, | ||
PDWORD | pPFNs, | ||
int | fOptions | ||
Win CE 6.0 and 5.0 compatible version of LockPages()
Locks into memory the specified region of the virtual address space
- Parameters
[in] lpvAddress Virtual Starting Address [in] cbSize Number of bytes to lock [in] pPFNs Array of physical frame numbers [in] fOptions Option Flags
- Return values
void* MapMemory | ( | DWORD | pa, |
DWORD | size | ||
Same as MapRegister() but can also map larger sections
- Parameters
[in] pa Physical address. [in] size Size to map in bytes.
- Return values
Virtual address
void* MapRegister | ( | DWORD | pa | ) |
Map Registers at a physical address (map areas up to the PAGE_SIZE).
- Parameters
- Return values
Virtual address
void MRLGetLibVersion | ( | DWORD * | pVerMaj, |
DWORD * | pVerMin, | ||
DWORD * | pBuild | ||
Returns the library Version.
- Parameters
[out] pVerMaj Returns the major version number. Set this parameter to NULL if not required. [out] pVerMin Returns the minor version number. Set this parameter to NULL if not required. [out] pBuild Returns the build number. Set this parameter to NULL if not required.
void* OALPAtoVA | ( | UINT32 | pa, |
BOOL | cached | ||
Get Virtual Address from Physical Address
- Parameters
[in] pa Physical Address [in] cached TRUE: Cached, FALSE: Not cached
- Return values
Virtual Address
void UnMapRegister | ( | volatile void * | pRegs | ) |
Unmap Register
- Parameters
[in] pRegs,: Pointer to virual address
BOOL VirtualCopy | ( | LPVOID | lpvDest, |
LPVOID | lpvSrc, | ||
DWORD | fdwProtect | ||
BOOL VirtualCopyCompat | ( | LPVOID | lpvDest, |
Win CE 6.0 and 5.0 compatible version of VirtualCopy()
- Parameters
[in] lpvDest Destination Virtual Address [in] lpvSrc Source Virtual Address [in] cbSize Number of bytes to copy [in] fdwProtect Specifies the protection desired
- Return values
BOOL VirtualSetAttributes | ( | LPVOID | lpvAddress, |
DWORD | dwNewFlags, | ||
DWORD | dwMask, | ||
LPDWORD | lpdwOldFlags | ||
BOOL VirtualSetAttributesCompat | ( | LPVOID | lpvAddress, |
Win CE 6.0 and 5.0 compatible version of VirtualSetAttributes()
Change the per-page attributes for a range of virtual memory
- Parameters
[in] lpvAddress Virtual Starting Address [in] cbSize Number of bytes [in] dwNewFlags The new flags values [in] dwMask Mask the bits to be changed [out] lpdwOldFlags If not NULL, returns the original value of the first page entry
- Return values
