Freq Lib API
Library to manage system clocks frequencies. More...
Data Structures
struct FRQPXAClocks struct FRQTEGClocksMacros | |
| #define | FRQ_VER_MAJ 2 |
| #define | FRQ_VER_MIN 3 |
| #define | FRQ_VER_BUILD 0 |
| #define | TEG_DFS_STATE_STOPPED 2 |
| #define | TEG_DFS_STATE_CLOSED_LOOP 3 |
| #define | CLKCFG_T 1 |
| #define | CLKCFG_F 2 |
| #define | CLKCFG_HT 4 |
| #define | CLKCFG_B 8 |
| #define | MDREFR_APD (1<<20) |
| #define | MDREFR_K0DB2 (1<<14) |
| #define | MDREFR_K1DB2 (1<<17) |
| #define | MDREFR_K0DB4 (1<<29) |
Enumerations | |
| enum | tPXAClockIDs { PXACPUClockID, PXARunClockID, PXASysClockID, PXAMemClockID, PXASDRAMClockID, PXASRAMClockID, PXALCDClockID } |
| PXA Clocks Definitions. More... | |
| enum | tTEGClockIDs { TEGCPUClockID, TEGSysClockID, TEGAVPClockID, TEGAHBClockID, TEGAPBClockID, TEGVIDClockID, TEGEMCClockID, TEGClockIDMax } |
| Tegra Clocks Definitions. More... | |
Functions | |
| void | FRQGetLibVersion (DWORD *pVerMaj, DWORD *pVerMin, DWORD *pBuild) |
| BOOL | FRQInit () |
| void | FRQDeInit () |
| Description: De-initialises the frequency library. More... | |
| BOOL | FRQPXAClocks *pxaClocks) |
| BOOL | FRQTEGClocks *tegClocks) |
| DWORD | FRQGetTEGDFSState () |
| BOOL | FRQSetPXAFrequencies (MULTCFG multiplierConfig) |
| DWORD | FRQSetPXA270Voltage (DWORD core_voltage) |
| BOOL | FRQSetTEGFrequency (tTEGClockIDs tegClockID, DWORD frequency) |
| BOOL | FRQSetTEGDFSState (DWORD state) |
| BOOL | TegFrq_Boost (const tTegDfsBusyHint *hints, DWORD numHints, tTegDfsBusyHintSyncMode mode) |
| void | SetFreq (MULTCFG mp) |
| MULTCFG | GetFreq (void) |
| void | CalcSystemFreq (MULTCFG ms, DWORD *pCpuClk, DWORD *pRunClk, DWORD *pSysClk, DWORD *pMemClk, DWORD *pSdramClk, DWORD *pSramClk, DWORD *pLcdClk) |
| DWORD | SetVoltage (DWORD core_voltage) |
Detailed Description
- Copyright
- Copyright (c) 2012 Toradex AG
- Author
- andy.kiser
- Rev
- 2863
- Date
- 2015-06-26 17:18:52 +0200 (Fr, 26 Jun 2015)
- Target Platforms:
- PXAxxx, Txx
| #define CLKCFG_B 8 |
| #define CLKCFG_F 2 |
| #define CLKCFG_HT 4 |
| #define CLKCFG_T 1 |
| #define FRQ_VER_BUILD 0 |
| #define FRQ_VER_MAJ 2 |
| #define FRQ_VER_MIN 3 |
| #define MDREFR_APD (1<<20) |
| #define MDREFR_K0DB2 (1<<14) |
| #define MDREFR_K0DB4 (1<<29) |
| #define MDREFR_K1DB2 (1<<17) |
| #define TEG_DFS_STATE_CLOSED_LOOP 3 |
| #define TEG_DFS_STATE_STOPPED 2 |
| enum tPXAClockIDs |
| enum tTEGClockIDs |
Function Documentation
| void CalcSystemFreq | ( | MULTCFG | ms, |
| DWORD * | pCpuClk, | ||
| DWORD * | pRunClk, | ||
| DWORD * | pSysClk, | ||
| DWORD * | pMemClk, | ||
| DWORD * | pSdramClk, | ||
| DWORD * | pSramClk, | ||
| DWORD * | pLcdClk | ||
Calculate the different clocks in HZ
- Parameters
[in] ms Multiplier Configuration Structure [out] pCPUClk CPU Clock Speed (RunMode Clock * XN) [out] pRunClk RunMode Clock Speed [out] pSysClk System Clock Speed [out] pMemClk Memory Clock Speed [out] pSdramClk SDRAM Clock Speed [out] pSRamClk SRAM Clock Speed [out] pLcdClk LCD Clock Speed
| void FRQDeInit | ( | ) |
| void FRQGetLibVersion | ( | DWORD * | pVerMaj, |
| DWORD * | pVerMin, | ||
| DWORD * | pBuild | ||
Description: Returns the library Version.
- Parameters
[out] pVerMaj Returns the major version number. Set this parameter to NULL if not required. [out] pVerMin Returns the minor version number. Set this parameter to NULL if not required. [out] pBuild Returns the build number. Set this parameter to NULL if not required.
| BOOL FRQGetPXAClocks | ( | FRQPXAClocks * | pxaClocks | ) |
Description: Returns the current PXA Clocks Frequencies.
- Parameters
in/out] pxaClocks Pointer to FRQPXAClocks structure that will be updated
- Return values
TRUE Success FALSE Failure
| BOOL FRQGetTEGClocks | ( | FRQTEGClocks * | tegClocks | ) |
Description: Returns the current Tegra Clocks Frequencies.
- Parameters
in/out] tegClocks Pointer to FRQTEGClocks structure that will be updated
- Return values
| DWORD FRQGetTEGDFSState | ( | ) |
Description: Returns the current state of DFS (Dynamic Frequency Switching).
- Return values
2 DFS Stopped 3 DFS Closed Loop
| BOOL FRQInit | ( | ) |
Description: Initialises the frequency library.
- Return values
| DWORD FRQSetPXA270Voltage | ( | DWORD | core_voltage | ) |
Set core voltage.
- Parameters
[in] core_voltage Voltage required in mV
- Return values
Voltage set in mV Remarks: !!!this is working on PXA270 only!!!
| BOOL FRQSetPXAFrequencies | ( | MULTCFG | multiplierConfig | ) |
Description: Sets the PXA Multiplier Configuration.
- Parameters
[in] multiplierConfig Multiplier Configuration Structure
- Return values
| BOOL FRQSetTEGDFSState | ( | DWORD | state | ) |
Description: Sets the state of DFS (Dynamic Frequency Switching).
- Parameters
[in] state New DFS State (2 = Stopped, 3 = Closed Loop)
- Return values
| BOOL FRQSetTEGFrequency | ( | tTEGClockIDs | tegClockID, |
| DWORD | frequency | ||
Description: Sets the given Tegra clock to the given frequency.
- Parameters
[in] tegClockID ID of the Tegra Clock to be set [in] frequency Frequency to set
- Return values
| MULTCFG GetFreq | ( | void | ) |
Get the actual processor frequencies
- Return values
| void SetFreq | ( | MULTCFG | mp | ) |
Set the processor frequencies according to mp
- Parameters
[in] mp Multiplier Configuration Structure
| DWORD SetVoltage | ( | DWORD | core_voltage | ) |
Set core voltage.
- Parameters
[in] core_voltage Voltage in mV
- Return values
Set voltage in mV Remarks: !!!this is working on PXA270 only!!!
| BOOL TegFrq_Boost | ( | const tTegDfsBusyHint * | hints, |
| DWORD | numHints, | ||
| tTegDfsBusyHintSyncMode | mode | ||
Description: Request / Release Minimum Clock Frequencies
- Parameters
[in] hints Array of boost informations. Each array element contains
- Clock name
- How long will it be boosted (can be infinite)
- Clock Frequency -> used to turn off boosting
- finish boost immediately, or gradually See tegra_dma.h for details.
[in] numHints Number of array elments [in] mode TegDfsBusyHintSyncMode_Async = function returns immediately TegDfsBusyHintSyncMode_Sync = function only returns after boost is active.
- Return values
