Flash Layout Vybrid and iMX7
Colibri VF50, Colibri VF61 and Colibri iMX7 use a common raw Nand flash to store OS, configuration and user data.
The flash device is organized as follows:
- the page size is 2kB
- a block consists of 64 pages.
The following flash layout describes the allocation of flash memory in the default configuration for Windows CE. Notes are inserted where the user can influence the flash layout.
| First page# (first block#) | size | Description |
| 0 (Block 0) | 2 kB | FCB factory data |
| 1 (Block 0) | 2 kB | Static config block |
| 2 (Block 0) | 2 kB | Bad block table |
| 3 (Block 0) | 122 kB | unused |
| 64 (Block 1) | 512 kB | Bootloader |
| 320 (Block 5) | 128 kB | Config block |
| 384 (Block 6) | 64752 kB1 | Registry, OS image and splash screen.2 |
| 32768 (Block 512) 3 | (total flash size) - 64 MB3 | Data used for user. Mounted as \FlashDisk on WinCE |
Footnotes
The size of the section for registry, OS and splash screen can be modified through the configblock setting
part.nonfssize.
The actual size is:((part.nonfssize * 1024) - 784) kB↩ -
The location of OS / Registry / Splashscreen inside this section depends on the order of flashing. These three parts can even be interleaved. ↩
Starting position and size are affected by the configblock setting
part.nonfssize.
The starting location is page(part.nonfssize * 512)(blockpart.nonfssize * 8).
The size is(total flash size in MB) - part.nonfssize MB. ↩
