.NET Compact Framework Flash Installer
The .NET Compact Framework Flash Installer is a .cab file which installs the .NET Compact Framework to the Colibri's Flash Disk of the Colibri module.
Versions
At the moment, installer for the following versions are available:
- .NET compact Framework 2.0.7045.0 (2.0 Service Pack 2)
- .NET compact Framework 3.5
- .NET compact Framework 3.9 ( this is only compatible with Windows Embedded Compact 2013 )
For the .NET compact Framework 3.5 there are additional string resources available, mainly to convert error numbers to readable string messages:
