GPIO Lib API
This library allows easy access to the GPIO pins. More...
Data Structures
struct PIN_INSTANCEMacros | |
| #define | GPIO_VER_MAJ 2 |
| #define | GPIO_VER_MIN 3 |
| #define | GPIO_VER_BUILD 0 |
| #define | DIR_IN 0 |
| #define | DIR_OUT 1 |
| #define | GPIO_EDGE_RISING 1 |
| #define | EDGE_RISING 1 |
| #define | GPIO_EDGE_FALLING 2 |
| #define | EDGE_FALLING 2 |
| #define | GPIO_EDGE_BOTH 3 |
| #define | EDGE_BOTH 3 |
| #define | MFP_PULLUP (MFP_PULL_SEL | MFP_PULLUP_EN) |
| #define | MFP_PULLDOWN (MFP_PULL_SEL | MFP_PULLDOWN_EN) |
| #define | MFP_NOPULL MFP_PULL_SEL |
| #define | MFP_EDGE_DISABLE MFP_EDGE_CLEAR |
| #define | MFP_PULL_SEL 0x8000 |
| #define | MFP_PULLUP_EN 0x4000 |
| #define | MFP_PULLDOWN_EN 0x2000 |
| #define | MFP_SLEEP_SEL 0x0200 |
| #define | MFP_SLEEP_DATA 0x0100 |
| #define | MFP_SLEEP_OE_N 0x0080 |
| #define | MFP_EDGE_CLEAR 0x0040 |
| #define | MFP_EDGE_FALL_EN 0x0020 |
| #define | MFP_EDGE_RISE_EN 0x0010 |
Tegra Specific Defines | |
| #define | TEGRA_GPIONUM(x, y) ((((x) - 'a') * 8) + y) |
| #define | TEGRA_MAX_GROUPNAME 6 |
| #define | TEGRA_MAX_GROUPNUM 115 |
| #define | TEGRA_NOPULL 0x00 |
| #define | TEGRA_PULLDOWN 0x01 |
| #define | TEGRA_PULLUP 0x02 |
| #define | TEGRA_TRISTATE_ENABLED 0x01 |
| #define | TEGRA_TRISTATE_DISABLED 0x00 |
Functions | |
| void | InitGPIOLib () |
| BOOL | InitGPIOLibEx (void *pRegAdress) |
| BOOL | InitGPIOLibTegraEx (void *pRegAddress, void *pRegTegraAPBMisc) |
| void | DeInitGPIOLib () |
Tegra Specific Functions | |
| BOOL | TegraSetTristatePinGroup (DWORD gpioNum, BOOL tristate) |
| DWORD | TegraGetTristatePinGroup (DWORD gpioNum) |
| BOOL | TegraSetPullStatePinGroup (DWORD gpioNum, DWORD pullState) |
| DWORD | TegraGetPullStatePinGroup (DWORD gpioNum) |
| BOOL | TegraGetPinGroupName (DWORD gpioNum, char *groupName) |
General Functions | |
| DWORD | GetPinDir (DWORD pinNum) |
| DWORD | GetGPIODir (DWORD gpioNum) |
| void | SetPinDir (DWORD gpioNum, BOOL dirOut) |
| void | SetGPIODir (DWORD gpioNum, BOOL dirOut) |
| DWORD | GetGPIOAltFn (DWORD gpioNum) |
| DWORD | GetPinAltFn (DWORD pinNum) |
| BOOL | SetPinAltFn (DWORD pinNum, DWORD altFn, BOOL dirOut) |
| void | SetGPIOAltFn (DWORD gpioNum, DWORD altFn, BOOL dirOut) |
| DWORD | GetGPIOMFPReg (DWORD gpioNum) |
| void | SetGPIOMFPReg (DWORD gpioNum, DWORD mfpRegVal) |
| BOOL | GetPinLevel (DWORD pinNum) |
| BOOL | GetGPIOLevel (DWORD gpioNum) |
| BOOL | SetPinLevel (DWORD pinNum, DWORD val) |
| void | SetGPIOLevel (DWORD gpioNum, DWORD val) |
| DWORD | GetGPIOEdgeDetect (DWORD gpioNum) |
| void | SetGPIOEdgeDetect (DWORD gpioNum, DWORD edge) |
| BOOL | GetGPIOEdgeStatus (DWORD gpioNum) |
| void | ClearGPIOEdgeStatus (DWORD gpioNum) |
| BOOL | GetGPIOFromPin (DWORD pin, BOOL extensionConnector, PIN_INSTANCE *gpio) |
| DWORD | GetGPIOFunctionalityAltFn (DWORD gpioNum) |
| void | GPIOGetLibVersion (DWORD *pVerMaj, DWORD *pVerMin, DWORD *pBuild) |
Detailed Description
- Copyright
- Copyright (c) 2012 Toradex AG
- Author:
- kia
- Rev:
- 1965
- Date:
- 2014-01-24 10:57:47 +0100 (Fr, 24 Jan 2014)
- Target Platforms:
- PXAxx, T20
| #define DIR_IN 0 |
| #define DIR_OUT 1 |
| #define EDGE_BOTH 3 |
| #define EDGE_FALLING 2 |
| #define EDGE_RISING 1 |
| #define GPIO_EDGE_BOTH 3 |
| #define GPIO_EDGE_FALLING 2 |
| #define GPIO_EDGE_RISING 1 |
| #define GPIO_VER_BUILD 0 |
| #define GPIO_VER_MAJ 2 |
| #define GPIO_VER_MIN 3 |
| #define MFP_EDGE_CLEAR 0x0040 |
| #define MFP_EDGE_DISABLE MFP_EDGE_CLEAR |
| #define MFP_EDGE_FALL_EN 0x0020 |
| #define MFP_EDGE_RISE_EN 0x0010 |
| #define MFP_NOPULL MFP_PULL_SEL |
| #define MFP_PULL_SEL 0x8000 |
| #define MFP_PULLDOWN (MFP_PULL_SEL | MFP_PULLDOWN_EN) |
| #define MFP_PULLDOWN_EN 0x2000 |
| #define MFP_PULLUP (MFP_PULL_SEL | MFP_PULLUP_EN) |
| #define MFP_PULLUP_EN 0x4000 |
| #define MFP_SLEEP_DATA 0x0100 |
| #define MFP_SLEEP_OE_N 0x0080 |
| #define MFP_SLEEP_SEL 0x0200 |
| #define TEGRA_GPIONUM | ( | x, | |
| y | |||
| ) | ((((x) - 'a') * 8) + y) |
| #define TEGRA_MAX_GROUPNAME 6 |
| #define TEGRA_MAX_GROUPNUM 115 |
| #define TEGRA_NOPULL 0x00 |
| #define TEGRA_PULLDOWN 0x01 |
| #define TEGRA_PULLUP 0x02 |
| #define TEGRA_TRISTATE_DISABLED 0x00 |
| #define TEGRA_TRISTATE_ENABLED 0x01 |
Function Documentation
| void ClearGPIOEdgeStatus | ( | DWORD | gpioNum | ) |
Clears GPIO Pin Edge Status
- Parameters
[in] gpioNum GPIO Pin Number
| void DeInitGPIOLib | ( | ) |
| DWORD GetGPIOAltFn | ( | DWORD | gpioNum | ) |
Get the Alternative Function setting of the specified GPIO Pin Number
- Parameters
[in] gpioNum,: GPIO Pin Number
- Return values
Alternative Function Setting Number
Remarks: On the Tegra, function can return -1 (0xFFFFFFFF)
| DWORD GetGPIODir | ( | DWORD | gpioNum | ) |
Get the Input/Output direction of the specified GPIO Pin Number
- Parameters
- Return values
GPIO Direction (0: Input, 1: Output)
| DWORD GetGPIOEdgeDetect | ( | DWORD | gpioNum | ) |
Get the GPIO Edge detect
- Parameters
- Return values
[EDGE_RISING(1),: rising edge, EDGE_FALLING(2): falling edge]
| BOOL GetGPIOEdgeStatus | ( | DWORD | gpioNum | ) |
Get GPIO Pin Edge Status
- Parameters
- Return values
Edge Status (0: Cleared, 1: Set)
| BOOL GetGPIOFromPin | ( | DWORD | pin, |
| BOOL | extensionConnector, | ||
| PIN_INSTANCE * | gpio | ||
Gets GPIO from SODIMM or Extension Pin.
- Parameters
[in] pin Pin Number (SODIMM pin or extension connector pin) [in] extensionConnector FALSE:SODIMM pin, TRUE:pin on Colibri PXA's FFC connector [out] gpio gpio Number with second instance
- Return values
TRUE Success FALSE Error
| DWORD GetGPIOFunctionalityAltFn | ( | DWORD | gpioNum | ) |
Gets the Alternative Function Status of a GPIO Pin
- Parameters
- Return values
Alternative Function Status Code Normal case 0; No GPIO Function: -1;
| BOOL GetGPIOLevel | ( | DWORD | gpioNum | ) |
Get the logic level of the specified GPIO Pin Number
- Parameters
- Return values
GPIO Level (False: Logic Low, True: Logic High)
| DWORD GetGPIOMFPReg | ( | DWORD | gpioNum | ) |
Get the MRPReg setting of the specified GPIO Pin Number
- Parameters
[in] gpioNum,: GPIO Number
- Return values
MFPReg data
| DWORD GetPinAltFn | ( | DWORD | pinNum | ) |
Get the Alternative Function setting of the specified SODIMM Pin Number
- Parameters
[in] pinNum SODIMM Pin Number
- Return values
| DWORD GetPinDir | ( | DWORD | pinNum | ) |
Get the Input/Output direction of the specified SODIMM Pin Number
- Parameters
- Return values
| BOOL GetPinLevel | ( | DWORD | pinNum | ) |
Get the logic level of the specified SODIMM Pin Number
- Parameters
[in] pinNum Sodimm Pin Number
- Return values
Pin Level (False: Logic Low, True: Logic High)
| void GPIOGetLibVersion | ( | DWORD * | pVerMaj, |
| DWORD * | pVerMin, | ||
| DWORD * | pBuild | ||
Outputs library version
- Parameters
[out] verMaj Major version number. Set this parameter to NULL if not required [out] verMin Minor version number. Set this parameter to NULL if not required [out] build Build number. Set this parameter to NULL if not required
| void InitGPIOLib | ( | ) |
| BOOL InitGPIOLibEx | ( | void * | pRegAdress | ) |
| BOOL InitGPIOLibTegraEx | ( | void * | pRegAddress, |
| void * | pRegTegraAPBMisc | ||
| void SetGPIOAltFn | ( | DWORD | gpioNum, |
| DWORD | altFn, | ||
| BOOL | dirOut | ||
Set the Alternative Function setting of the specified GPIO Pin Number
- Parameters
[in] gpioNum,: GPIO Number [in] altFn,: Alternative Function Setting, use -1 to configure as GPIO. [in] dirOut,: GPIO Direction [False: Input, True: Output]
| void SetGPIODir | ( | DWORD | gpioNum, |
| BOOL | dirOut | ||
Set the Input/Output direction of the specified GPIO Pin Number
- Parameters
[in] gpioNum,: GPIO Pin Number [in] dirOut Direction (0: Input, 1:Output)
| void SetGPIOEdgeDetect | ( | DWORD | gpioNum, |
| DWORD | edge | ||
Set the GPIO Pin Edge Detect - deprecated, Please use SetGPIOIrqEdge() in IntLib.
- Deprecated:
- Please use SetGPIOIrqEdge() in IntLib.
- Parameters
[in] gpioNum GPIO Pin Number [in] edge [EDGE_RISING(1): rising edge, EDGE_FALLING(2): falling edge]
| void SetGPIOLevel | ( | DWORD | gpioNum, |
| DWORD | val | ||
Set the Logic level of a GPIO Pin
- Parameters
[in] gpioNum GPIO Pin Number [in] val [0: Logic Low >0: Logic High]
| void SetGPIOMFPReg | ( | DWORD | gpioNum, |
| DWORD | mfpRegVal | ||
Set the MRPReg setting of the specified GPIO Pin Number
- Parameters
[in] gpioNum,: GPIO Number [in] mfpRegVal,: MFPREg Data
| BOOL SetPinAltFn | ( | DWORD | pinNum, |
| DWORD | altFn, | ||
| BOOL | dirOut | ||
Set the Alternative Function setting of the specified SODIMM Pin Number
- Parameters
[in] pinNum,: SODIMM Pin Number [in] altFn,: Alternative Function Setting, use -1 to configure as GPIO. [in] dirOut,: GPIO Direction [False: Input, True: Output]
- Return values
| void SetPinDir | ( | DWORD | gpioNum, |
| BOOL | dirOut | ||
Set the Input/Output direction of the specified SODIMM Pin Number
- Parameters
[in] ponNum SODIMM Pin Number [in] dirOut Direction (0: Input, 1:Output)
| BOOL SetPinLevel | ( | DWORD | pinNum, |
| DWORD | val | ||
Set the logic level of the specified SODIMM Pin Number
- Parameters
[in] pinNum SODIMM Pin. Number [in] val [0: Logic Low >0: Logic High]
- Return values
| BOOL TegraGetPinGroupName | ( | DWORD | gpioNum, |
| char * | groupName | ||
Get the Pin Group Name of a GPIO pin.
- Parameters
[in] gpioNum GPIO Pin Number [out] *groupName Ascii string containing the name of the Pin group max TEGRA_MAX_GROUPNAME characters.
- Return values
| DWORD TegraGetPullStatePinGroup | ( | DWORD | gpioNum | ) |
Get the Pullup/Pulldown setting of a GPIO pin group
- Parameters
- Return values
Pull status (0:floating, 1:pulldown, 2:pullup)
| DWORD TegraGetTristatePinGroup | ( | DWORD | gpioNum | ) |
Get the Tristate setting of a pin group of GPIO pins.
- Parameters
- Return values
1 Tristated 0 Active
| BOOL TegraSetPullStatePinGroup | ( | DWORD | gpioNum, |
| DWORD | pullState | ||
Set the Pullup/Pulldown setting of a pin group of GPIO pins.
- Parameters
[in] gpioNum GPIO Pin Number [in] pullState (0:floating, 1:pulldown, 2:pullup)
- Return values
Remarks: Please note - this affects the whole pin group.
| BOOL TegraSetTristatePinGroup | ( | DWORD | gpioNum, |
| BOOL | tristate | ||
Updates the Tristate setting of a pin group of GPIO pins.
- Parameters
[in] gpioNum GPIO Pin Number [in] tristate (1:tristated, 0:detristated)
- Return values
