DMA Library API
Library for DMA handling, including channel allocation and DMA transfer control.
Data Structures
struct DMA_GLOBALS Memory mapped DMA Globals structure - sorted by DMA channel. More...Macros | |
| #define | DMA_VER_MAJ 1 |
| #define | DMA_VER_MIN 3 |
| #define | DMA_VER_BUILD 1 |
| #define | DMA_MAX_CHAN 32 |
| number of available DMA channels More... | |
| #define | DMA_USAGE_LEN 32 |
| maximum string length for a descriptive text (DMA channel usage) More... | |
| #define | DMA_SHARED_FILENAME (TEXT("ColibriDmaGlobals")) |
| Memory mapped filename used by the DMALib for interprocess sharing of DMA data structures. More... | |
| #define | PERIPH_SSP1RX (13) |
| #define | PERIPH_SSP1TX (14) |
| #define | PERIPH_SSP2RX (15) |
| #define | PERIPH_SSP2TX (16) |
| #define | PERIPH_SSP3RX (66) |
| #define | PERIPH_SSP3TX (67) |
| #define | PERIPH_SSP4RX (71) |
| #define | PERIPH_SSP4TX (72) |
| #define | PERIPH_CIF1 (68) |
| #define | PERIPH_CIF2 (69) |
| #define | PERIPH_CIF3 (70) |
| #define | DCMD_INCSRCADDR (1 << 31) |
| Source Address Increment. More... | |
| #define | DCMD_INCTRGADDR (1 << 30) |
| Target Address Increment. More... | |
| #define | DCMD_FLOWSRC (1 << 29) |
| Source Flow Control. More... | |
| #define | DCMD_FLOWTRG (1 << 28) |
| Target Flow Control. More... | |
| #define | DCMD_CIF_DMA (1 << 27) |
| Create a PXA3xx CIF descriptor. More... | |
| #define | DCMD_CMPEN (1 << 25) |
| Descriptor Compare Enable. More... | |
| #define | DCMD_ADDRMODE (1 << 23) |
| Addressing Mode. More... | |
| #define | DCMD_STARTIRQEN (1 << 22) |
| Start Interrupt Enable. More... | |
| #define | DCMD_ENDIRQEN (1 << 21) |
| End Interrupt Enable. More... | |
| #define | DCMD_FLYBYS (1 << 20) |
| Fly-By Source (PXA270 only) More... | |
| #define | DCMD_FLYBYT (1 << 19) |
| Fly-By Target (PXA270 only) More... | |
| #define | DCMD_BSIZE8 (1 << 16) |
| #define | DCMD_BSIZE16 (2 << 16) |
| #define | DCMD_BSIZE32 (3 << 16) |
| #define | DCMD_BWIDTH8 (1 << 14) |
| #define | DCMD_BWIDTH16 (2 << 14) |
| #define | DCMD_BWIDTH32 (3 << 14) |
| #define | DCMD_LENGTH 0x01fff |
| Length of Transfer in Bytes (MASK) More... | |
| #define | DCSR_RUN (1 << 31) |
| Run Bit (read / write) More... | |
| #define | DCSR_NODESC (1 << 30) |
| No-Descriptor Fetch (read / write) More... | |
| #define | DCSR_STOPIRQEN (1 << 29) |
| Stop Interrupt Enable (when the descriptor is done) (read / write) More... | |
| #define | DCSR_EORIRQEN (1 << 28) |
| End-of-Receive Interrupt Enable. More... | |
| #define | DCSR_EORJMPENT (1 << 27) |
| Jump to next Descriptor on End-of-Receive. More... | |
| #define | DCSR_EORSTOPEN (1 << 26) |
| Stop Channel on End-of-Receive. More... | |
| #define | DCSR_SETCMPST (1 << 25) |
| Set Descriptor Compare Status. More... | |
| #define | DCSR_CLRCMPST (1 << 24) |
| Clear Descriptor Compare Status. More... | |
| #define | DCSR_CMPST (1 << 10) |
| #define | DCSR_EORINT (1 << 9) |
| End of Receive. More... | |
| #define | DCSR_REQPEND (1 << 8) |
| Request Pending (read-only) More... | |
| #define | DCSR_RASINTR (1 << 4) |
| Request after Channel Stops. More... | |
| #define | DCSR_STOPINTR (1 << 3) |
| Stop State (read-only) More... | |
| #define | DCSR_ENDINTR (1 << 2) |
| End Interrupt (read / write) More... | |
| #define | DCSR_STARTINTR (1 << 1) |
| Start Interrupt (read / write) More... | |
| #define | DCSR_BUSERRINTR (1 << 0) |
| Bus Error Interrupt (read / write) More... | |
| #define | DRCMR_MAPVLD (1 << 7) |
| Valid Channel mapped. More... | |
| #define | DDADR_STOP (1 << 0) |
Functions | |
| void | DMAGetLibVersion (DWORD *pVerMaj, DWORD *pVerMin, DWORD *pBuild) |
| Initialisation. More... | |
| void | DMAInit (void) |
| Initializes the DMA Library. More... | |
| void | DMADeInit (void) |
| De-Initializes the DMA Library. More... | |
| DWORD | DMAAllocChannel (DWORD periph) |
| DMA Channel Management. More... | |
| DWORD | DMAAllocChannelEx (DWORD periph, DWORD priority) |
| void | DMAReleaseChannel (DWORD chan) |
| void | DMAReleaseDevice (DWORD periph) |
| void | DMASetChannelUsage (DWORD chan, CHAR *szChanUsage, DWORD cBytes) |
| DWORD | DMAGetChannelUsage (DWORD chan, CHAR *szChanUsage, DWORD cBytes) |
DMA Preparation | |
| BOOL | DMACreateTransferDescriptors (DWORD sadr, DWORD tadr, DWORD len, DWORD flags, BOOL loop, MEM_T *pMem) |
| BOOL | DMADestroyTransferDescriptors (MEM_T *pMem) |
| BOOL | DMAAllocBuffer (MEM_T *pMem, DWORD size) |
| BOOL | DMAFreeBuffer (MEM_T *pMem) |
DMA Real Time Control | |
| DWORD | DMAStartTransferEx (DWORD chan, MEM_T *pMem, DWORD flags, BOOL block) |
| void | DMAStartShortTransfer (DWORD chan, DWORD sadr, DWORD tadr, DWORD len, DWORD cmd, DWORD csr) |
| DWORD | DMAStartShortTransferEx (DWORD chan, DWORD sadr, DWORD tadr, DWORD len, DWORD cmd, DWORD csr, BOOL block) |
| void | _DMAStartTransfer (DWORD chan, MEM_T *pMem, DWORD flags) |
| void | DMAWaitTransferEnd (DWORD chan) |
| void | DMAStopTransfer (DWORD chan) |
| BOOL | DMAGetTrgSrcAdd (DWORD chan, DWORD *dtadr, DWORD *dsadr) |
| Get current Target and Source address. . More... | |
| DWORD | DMAGetLen (DWORD chan) |
| #define DCMD_ADDRMODE (1 << 23) |
Addressing Mode.
| #define DCMD_BSIZE16 (2 << 16) |
| #define DCMD_BSIZE32 (3 << 16) |
| #define DCMD_BSIZE8 (1 << 16) |
| #define DCMD_BWIDTH16 (2 << 14) |
| #define DCMD_BWIDTH32 (3 << 14) |
| #define DCMD_BWIDTH8 (1 << 14) |
| #define DCMD_CIF_DMA (1 << 27) |
| #define DCMD_CMPEN (1 << 25) |
| #define DCMD_ENDIRQEN (1 << 21) |
| #define DCMD_FLOWSRC (1 << 29) |
| #define DCMD_FLOWTRG (1 << 28) |
| #define DCMD_FLYBYS (1 << 20) |
| #define DCMD_FLYBYT (1 << 19) |
| #define DCMD_INCSRCADDR (1 << 31) |
| #define DCMD_INCTRGADDR (1 << 30) |
| #define DCMD_LENGTH 0x01fff |
| #define DCMD_STARTIRQEN (1 << 22) |
| #define DCSR_BUSERRINTR (1 << 0) |
| #define DCSR_CLRCMPST (1 << 24) |
| #define DCSR_CMPST (1 << 10) |
| #define DCSR_ENDINTR (1 << 2) |
| #define DCSR_EORINT (1 << 9) |
End of Receive.
| #define DCSR_EORIRQEN (1 << 28) |
| #define DCSR_EORJMPENT (1 << 27) |
| #define DCSR_EORSTOPEN (1 << 26) |
| #define DCSR_NODESC (1 << 30) |
| #define DCSR_RASINTR (1 << 4) |
| #define DCSR_REQPEND (1 << 8) |
| #define DCSR_RUN (1 << 31) |
| #define DCSR_SETCMPST (1 << 25) |
| #define DCSR_STARTINTR (1 << 1) |
| #define DCSR_STOPINTR (1 << 3) |
| #define DCSR_STOPIRQEN (1 << 29) |
| #define DDADR_STOP (1 << 0) |
| #define DMA_MAX_CHAN 32 |
| #define DMA_SHARED_FILENAME (TEXT("ColibriDmaGlobals")) |
| #define DMA_USAGE_LEN 32 |
| #define DMA_VER_BUILD 1 |
| #define DMA_VER_MAJ 1 |
| #define DMA_VER_MIN 3 |
| #define DRCMR_MAPVLD (1 << 7) |
| #define PERIPH_CIF1 (68) |
| #define PERIPH_CIF2 (69) |
| #define PERIPH_CIF3 (70) |
| #define PERIPH_SSP1RX (13) |
| #define PERIPH_SSP1TX (14) |
| #define PERIPH_SSP2RX (15) |
| #define PERIPH_SSP2TX (16) |
| #define PERIPH_SSP3RX (66) |
| #define PERIPH_SSP3TX (67) |
| #define PERIPH_SSP4RX (71) |
| #define PERIPH_SSP4TX (72) |
| enum DMA_CHANNEL_PRIORITY |
| enum DMA_PERIPH_ID |
DMA peripheral device DRCMR IDs.
Function Documentation
| void _DMAStartTransfer | ( | DWORD | chan, |
| MEM_T * | pMem, | ||
| DWORD | flags | ||
Start a DMA transfer which was previously setup using DMACreateTransferDescriptors().
Needed to be renamed because in Wince 6.0 we have a naming conflict with a CEDDK function!!
- Parameters
[in] chan DMA channel number [in] pMem Physical and virtual address of the descriptor [in] flags Flags for the DMA Control/Status Register
| BOOL DMAAllocBuffer | ( | MEM_T * | pMem, |
| DWORD | size | ||
Allocate physical memory that can be used as source or target for DMA transfers.
- Parameters
[out] pMem Physical and virual address of the allocated memory [in] size Required memory size in bytes
- Return values
TRUE Success FALSE Error occured
| DWORD DMAAllocChannel | ( | DWORD | periph | ) |
Searches for a free channel and allocates it.
- Parameters
[in] periph DMA peripheral device DRCMR ID
- Return values
-1 No free channel found. >=0 Allocated DMA channel number
- Deprecated:
- Obsolete fuction!
| DWORD DMAAllocChannelEx | ( | DWORD | periph, |
| DWORD | priority | ||
Searches for a free channel with specific priority and allocates it.
- Parameters
[in] periph DMA peripheral device DRCMR ID [in] priority Requested Priority. See DMA_CHANNEL_PRIORITY
- Return values
-1 No free channel found for the requested priority. >=0 Allocated DMA channel number.
| BOOL DMACreateTransferDescriptors | ( | DWORD | sadr, |
| DWORD | tadr, | ||
| DWORD | len, | ||
| DWORD | flags, | ||
| BOOL | loop, | ||
| MEM_T * | pMem | ||
Create DMA Transfer descriptor.
NOTE: TransferDescriptors in RAM are only required for transfers of 8kB or more.
- Parameters
[in] sadr Source address [in] tadr Target address [in] len Length of Transfer in Bytes, see also DMA Command Registers [in] flags Flags for the DMA Command Registers [in] loop TRUE: DMA descriptor chain is a loop [out] pMem Physical and virtual address of the descriptor
- Return values
| void DMADeInit | ( | void | ) |
| BOOL DMADestroyTransferDescriptors | ( | MEM_T * | pMem | ) |
Release memory reserved for the transfer descriptor.
- Parameters
[in,out] pMem Physical and virtual address of the descriptor
- Return values
| BOOL DMAFreeBuffer | ( | MEM_T * | pMem | ) |
Free the physical memory that was allocated by DMAAllocBuffer()
- Parameters
[in,out] pMem Physical and virtual address of the allocated memory
- Return values
| DWORD DMAGetChannelUsage | ( | DWORD | chan, |
| CHAR * | szChanUsage, | ||
| DWORD | cBytes | ||
Get the descriptive text for what a DMA channel is used for.
- Parameters
[in] chan DMA channel number [out] szChanUsage Descriptive Text (Zero-terminated ASCII string) [in] cBytes Maximum allowed String Length in Bytes
- Return values
DWORD Actually returned string length.
| DWORD DMAGetLen | ( | DWORD | chan | ) |
Get number of bytes already transferred.
- Parameters
- Return values
DWORD Number of bytes already transferred.
| void DMAGetLibVersion | ( | DWORD * | pVerMaj, |
| DWORD * | pVerMin, | ||
| DWORD * | pBuild | ||
Initialisation.
Returns the library Version.
- Parameters
[out] pVerMaj Returns the major version number. Set this parameter to NULL if not required. [out] pVerMin Returns the minor version number. Set this parameter to NULL if not required. [out] pBuild Returns the build number. Set this parameter to NULL if not required.
| BOOL DMAGetTrgSrcAdd | ( | DWORD | chan, |
| DWORD * | dtadr, | ||
| DWORD * | dsadr | ||
- Parameters
[in] chan DMA channel number [out] dtadr Target address [out] dsadr Source address
- Return values
| void DMAInit | ( | void | ) |
| void DMAReleaseChannel | ( | DWORD | chan | ) |
Release/free DMA Channel
- Parameters
[in] chan DMA channel number. Remarks: ATTENTION! Parameter changed to channel number.
Used to be peripheral device ID which is inappropriate.
See new Function: DMAReleaseDevice.
| void DMAReleaseDevice | ( | DWORD | periph | ) |
Releases Device allocated DMA Channel.
- Parameters
| void DMASetChannelUsage | ( | DWORD | chan, |
| DWORD | cBytes | ||
Set a descriptive text for what a DMA channel is used for.
- Parameters
[in] chan DMA channel number [in] szChanUsage Descriptive Text (Zero-terminated ASCII string) [in] cBytes String Length in Bytes
| void DMAStartShortTransfer | ( | DWORD | chan, |
| DWORD | sadr, | ||
| DWORD | tadr, | ||
| DWORD | len, | ||
| DWORD | cmd, | ||
| DWORD | csr | ||
Start DMA transfer non descriptor mode.
NOTE: This can only be used for transfers < 8kB
- Parameters
[in] chan DMA channel number [in] sadr Source address [in] tadr Target address [in] len Length of Transfer in bytes (max. 8191) [in] cmd Flags for the DMA Command Registers [in] csr Flags for the DMA Control/Status Register
| DWORD DMAStartShortTransferEx | ( | DWORD | chan, |
| DWORD | sadr, | ||
| DWORD | tadr, | ||
| DWORD | len, | ||
| DWORD | cmd, | ||
| DWORD | csr, | ||
| BOOL | block | ||
Start DMA transfer non-descriptor mode.
NOTE: This can only be used for transfers < 8Kb
- Parameters
[in] chan DMA channel number [in] sadr Source address [in] tadr Target address [in] len Length of Transfer in bytes (max. 8191) [in] cmd Flags for the DMA Command Registers [in] csr Flags for the DMA Control/Status Register [in] block TRUE: function returns after DMA is finished
FALSE: function returns immediately
- Return values
TRUE Success FALSE Timeout detected
| DWORD DMAStartTransferEx | ( | DWORD | chan, |
| DWORD | flags, | ||
| BOOL | block | ||
- Parameters
[in] chan DMA channel number [in] pMem Physical and virtual address of the descriptor [in] flags Flags for the DMA Command Registers [in] block TRUE=function returns after DMA is finished
FALSE= function returns immediately
- Return values
| void DMAStopTransfer | ( | DWORD | chan | ) |
Early stop DMA transfer
- Parameters
| void DMAWaitTransferEnd | ( | DWORD | chan | ) |
Wait until DMA transfer is finished
- Parameters
