Clk Lib API
Library to manange clock settings. More...
Macros
##define CLKLIB_VERSION_MAJOR 3 Version Info. More...
#define CLKLIB_VERSION_MINOR 3 #define CLKLIB_VERSION_BUILD 0 #define USE_DEFAULT_CLOCK_SOURCE 255 #define USE_DEFAULT_CLOCK_DIVIDER 4294967295
Enumerations | |
Tegra T20 defines | |
enum | tClockOptimise ClockOptimiseForPrecision |
Functions | |
void | ClkLibGetLibVersion (DWORD *VersionMajor, DWORD *VersionMinor, DWORD *Build) |
void | ClkLibInit (void) |
Initialises the library, call before calling any other functions. More... | |
void | ClkLibDeInit (void) |
Releases the library resources, call when finsihed with the library. More... | |
BOOL | ClkLibSetClock (DWORD clockID, BOOL status) |
BOOL | ClkLibSetClockEx (DWORD clockID, BOOL status, DWORD ClockDivider) |
DWORD | ClkLibSetClockFrequency (DWORD clockID, DWORD minimumFrequency, DWORD maximumFrequency, tClockOptimise optimiseTarget) |
BOOL | ClkLibGetClockEnableStatus (DWORD clockID) |
DWORD | ClkLibGetClockFrequency (DWORD clockID) |
void | ClkLibWaitus (UINT32 uSec) |
Deprecated legacy declarations | |
void | InitClkLib (void) |
void | DeInitClkLib (void) |
BOOL | SetClk (DWORD clkID, BOOL value) |
BOOL | SetClkEx (DWORD clkID, BOOL value, DWORD ClkDivider) |
BOOL | GetClkEn (DWORD clkID) |
void | Waitus (UINT32 uSec) |
void | CLKGetLibVersion (DWORD *pVerMaj, DWORD *pVerMin, DWORD *pBuild) |
Detailed Description
- Copyright
- Copyright (c) 2013 Toradex AG
- Author:
- kia
- Rev:
- 2101
- Date:
- 2014-03-10 14:27:38 +0100 (Mo, 10 Mrz 2014)
- Target Platforms:
- PXAxxx / T20 / T30
#define CLKLIB_VERSION_BUILD 0 |
#define CLKLIB_VERSION_MAJOR 3 |
Version Info.
#define CLKLIB_VERSION_MINOR 3 |
#define USE_DEFAULT_CLOCK_DIVIDER 4294967295 |
#define USE_DEFAULT_CLOCK_SOURCE 255 |
enum tClockOptimise |
Function Documentation
void CLKGetLibVersion | ( | DWORD * | pVerMaj, |
DWORD * | pVerMin, | ||
DWORD * | pBuild | ||
Returns the library Version.
- Deprecated:
- Please use ClkLibGetLibVersion()
- Parameters
[out] pVerMaj Returns the major version number. Set this parameter to NULL if not required. [out] pVerMin Returns the minor version number. Set this parameter to NULL if not required. [out] pBuild Returns the build number. Set this parameter to NULL if not required.
void ClkLibDeInit | ( | void | ) |
BOOL ClkLibGetClockEnableStatus | ( | DWORD | clockID | ) |
Returns the clock enable status for a specific peripheral
- Parameters
[in] clockID Clock ID (refer to ClkLib.h)
- Return values
TRUE,: Success, FALSE: Error
DWORD ClkLibGetClockFrequency | ( | DWORD | clockID | ) |
Gets the current frequency of the given clock. Tegra 2 Only
- Parameters
- Return values
Actual Frequency configured, 0 = function failed
void ClkLibGetLibVersion | ( | DWORD * | VersionMajor, |
DWORD * | VersionMinor, | ||
DWORD * | Build | ||
Returns the library version.
- Parameters
[out] VersionMajor Returns the major version number. Set this parameter to NULL if not required. [out] VersionMinor Returns the minor version number. Set this parameter to NULL if not required. [out] Build Returns the build number. Set this parameter to NULL if not required.
void ClkLibInit | ( | void | ) |
BOOL ClkLibSetClock | ( | DWORD | clockID, |
BOOL | status | ||
Enables or disables the clock for a specific peripheral.
- Parameters
[in] clockID Clock ID (refer to ClkLib.h) [in] status TRUE: Enable clock, FALSE: Disable clock
- Return values
BOOL ClkLibSetClockEx | ( | DWORD | clockID, |
BOOL | status, | ||
DWORD | ClockDivider | ||
Enables / disables clock for a specific peripheral - extended version.
- Parameters
[in] clockID Clock ID (refer to ClkLib.h) [in] status TRUE for enable clock, FALSE for disable clock [in] clockDivider Clock Divisor, set to USE_DEFAULT_CLOCK_DIVIDER to use default (Tegra only)
- Return values
DWORD ClkLibSetClockFrequency | ( | DWORD | clockID, |
DWORD | minimumFrequency, | ||
DWORD | maximumFrequency, | ||
tClockOptimise | optimiseTarget | ||
Sets the Clock Speed as close as possible to the provided frequency. Tegra 2 Only
- Parameters
[in] clockID Clock ID (refer to ClkLib.h) [in] minimumFrequency Lowest allowed frequency [Hz] [in] maximumFrequency Highest allowed frequency [Hz] [in] optimiseTarget ClkOptimiseForPower = select the slowest clock source which can be used to generate a frequency in the requested range
ClkOptimizeForPrecision = select the clock source which can generate a clock as close as possible to the average of minimumFrequency and maximumFrequency
- Return values
void ClkLibWaitus | ( | UINT32 | uSec | ) |
Delay with microsecond resolution.
- Parameters
[in] uSec Number of microseconds.
void DeInitClkLib | ( | void | ) |
- Deprecated:
- Please use ClkLibDeInit()
BOOL GetClkEn | ( | DWORD | clkID | ) |
Request clock enable status for a specific peripheral
- Deprecated:
- Please use ClkLibGetClockEnableStatus()
- Parameters
[in] clkID Clock ID (refer to ClkLib.h)
- Return values
void InitClkLib | ( | void | ) |
- Deprecated:
- Please use ClkLibInit()
BOOL SetClk | ( | DWORD | clkID, |
BOOL | value | ||
Enables / disables clock for a specific peripheral.
- Deprecated:
- Please use ClkLibSetClock()
- Parameters
[in] clkID Clock ID (refer to ClkLib.h) [in] value TRUE: Enable clock, FALSE: Disable clock
- Return values
BOOL SetClkEx | ( | DWORD | clkID, |
BOOL | value, | ||
DWORD | ClkDivider | ||
- Deprecated:
- Please use ClkLibSetClockEx()
- Parameters
[in] clkID Clock ID (refer to ClkLib.h) [in] value TRUE for enable clock, FALSE for disable clock [in] ClkDivider Clock Divisor, set to USE_DEFAULT_CLOCK_DIVIDER to use default (Tegra only)
- Return values
void Waitus | ( | UINT32 | uSec | ) |
- Deprecated:
- Please use ClkLibWaitus()
- Parameters
