IOCTL HAL REBOOT
Using this IOCTL, you can reboot the system.
Please note, the following SoCs support only cold boot:
- VF50
- VF61
- i.MX6
- i.MX7
Definitions
# define FILE_DEVICE_HAL 0x101
# define METHOD_BUFFERED 0x0
# define FILE_ANY_ACCESS 0x0
# define CTL_CODE( DeviceType, Function, Method, Access ) (((DeviceType) << 16) | ((Access) << 14) | ((Function) << 2) | (Method))
# define IOCTL_HAL_REBOOT CTL_CODE(FILE_DEVICE_HAL, 15, METHOD_BUFFERED, FILE_ANY_ACCESS)
BOOL KernelIoControl(DWORD dwIoControlCode, LPVOID lpInBuf, DWORD nInBufSize, LPVOID lpOutBuf, DWORD nOutBufSize, LPDWORD lpBytesReturned);
Sample
// To force a Cold Boot: let the 2nd function parameter point to a value 0
// *lpInBuf = 0;
// To force a Warm Boot: let the 2nd function parameter be NULL
// lpInBuf = 0;
if(coldBoot)
DWORD zero=0;
KernelIoControl(IOCTL_HAL_REBOOT, &zero, 4, NULL, 0, NULL);
else
KernelIoControl(IOCTL_HAL_REBOOT, NULL, 0, NULL, 0, NULL);
