Windows CE Library - SPI Library (SPILib)
Description
This library manages the SPI interfaces via polling
Current Version
V5.4
Application Notes
SPILib supports up to 6 SPI ports on Colibri and Apalis modules.
The SPILib can be used in PIO-mode or DMA mode. PIO mode is more efficient for transfers < 32 SPI Words.
In SPI slave mode, data can easily get lost if packets are larger than FIFO size (32 frames on T20/T30). Use DMA mode instead.
Library API
Other Resources
Windows CE Libraries Overview
Colibri SPI
How to use SPI library
Revision History
DateRevChange Notes
29/06/2015V5.4Fix default pin configuration for PXA300.
Implemented automatic default pin selection for all SPI channels on Colibri T20/T30 and Apalis T30.
Added code to detect and resolve conflicting AltFn settings on multiple pins (Tegra).
Added configuration options for Tegra (wait method, chip select number/behavior, packed mode).
Support all 6 SPI channels on T30. This is a requirement for CAN1 on Apalis T30.
Replace printf debug messages with regular debug output.
Improve stability of SPI communication on Tegra. Performance may be slightly degraded.
30/10/2014V5.3Fix issue on T20/T30 modules: Small SPI transfers using DMA caused the application to freeze.
Fix issue on T20/T30 modules: SPI transfers using DMA caused the application to freeze, if transfer size was not a multiple of 4.
27/05/2014V5.2Non-standard SPI pin configurations can now be defined as GPIO numbers instead of SODIMM pins. This is to support on-module SPI channels, e.g. for the Apalis on-module CAN controllers
Adjust default SPI pin configurations for Apalis
15/04/2014V5.1Add TegSpiSetWaitMethod() to choose between interrput-driven and busyLoop waiting
Use DMA-like SPI control method even in non-DMA mode to prevent possible data loss of received data.
Remove deprecated functions TegWriteSPIUnpacdked() and TegReadSPIUnpacked()
Fix issue that caused a data abort when calling SPIInit() the 2nd time
11/03/2014V5.0Fix bit rate calculation
Pre-allocate memory for DMA, instead of allocating it for each transfer
Performance improvements
Fix pin initialization
23/09/2013V4.1Change default SDK to Colibri600 / Added support for T30's SPI5 and SPI6
12/08/2013V4.0.1Improved performance of SPIReadWritePolling(), SPIReadPolling() and SPIWritePolling() on Tegra processors
