Battery Less Operation
The AMI BIOS (Version J007, J907, J009, J011) for Woodpecker and Robin Modules does not implement a function to save the BIOS Settings into flash. Therefore a battery is required if the computer modules need to run with other settings than the default ones.
This functionality will be implemented in one of the next BIOS releases. With this functionality it will be possible to save all BIOS settings (except date and time ;-) permanently to the flash and a backup battery will be no longer necessary.
