Windows CE Library - CANLib-SJA1000
Description​
This library interfaces to the SJA1000 Stand-Alone CAN Controller.
Current Version​
V3.3.2
Application Notes​
CANLib-SJA1000 interfaces to a SJA1000 Stand-Alone CAN controller via a parallel bus interface.
The SJA1000 is located on the carrier board hosting the module running the library.
The Colibri Evaluation Board V2.1 contains an instance of this chip.
The library supports one instance of the interface on TXX modules and up to eight instances on PXAxxx modules.
Library API​
The library API can be viewed here.
Other Resources​
Windows CE Libraries Overview
Data Sheet
Revision History​
DateRevChange Notes
23/09/2013V3.3.2Change default SDK to Colibri600
12/08/2013V3.3.1Added support for T30
17/06/2013V3.3.0Added CANReInitialise() to DLL Definition File
