Windows CE Library - Map Register Library - (MapRegLib)
Description
This library provides for the mapping of physical registers to virtual addresses.
Current Version
V1.3
Application Notes
MapRegLib can be used to map physical registers and memory into the virtual address space of a Win CE application.
MapRegLib can also be used to allocate and free memory for use as buffers, etc to be used with DMA access to peripherals.
Library API
Other Resources
Revision History
| Date | Rev | Change Notes |
| 27/05/2014 | V1.3 | VirtualSetAttributesCompat(): Add support for Tegra, but only for BSP V1.3beta2 and later |
| 11/03/2014 | V1.2 | Fix: AllocPhysMemCompat() did not work on old T20/T30 images |
| 17/06/2013 | V1.1.1 | Updated to work with Apalis T30 |
