RAMDisk (WinCE)
RAMDisk is a WinCE feature which allows you to take a portion of your system memory and use it as a disk drive. This reduces the available amount of free system memory of course.
CE5
Follow the steps below to create and mount a RAMDisk:
  • Download the ramdisk.zip file.
  • Unzip the file and copy the ramdisk.dll to your WinCE device "\FlashDisk\System"
  • Copy the ceramdrv.exe tool to the root of the module.
  • On the WinCE device open Start->Programs->Command Prompt.
  • To create a RAMDisk with the size of 10MB, type:
ceramdrv 10240
Note: Command line parameter is size in KB.
  • To make this persistent, save the registry: Start->Programs->Colibri Tools->Save Reg.
CE6/CE7
CE6 and CE7 might work with the WinCE 5 steps above, but was not tested.
