Windows Embedded Compact License and Components
Toradex ships some of its Computer Modules including a Windows Embedded Compact / WinCE runtime license. For detailed information about the licenses please contact your local Microsoft distributor.
You can find a list of products with included runtime license on our Main Website. Select a product and look at the "Module Feature" tab for further details.
You can download all available OS Images here
Windows Embedded Compact is reaching end-of-life, please consider using Torizon, our easy-to-use platform that has been designed as a migration path for WinCE users. If you already use WinCE, read the article Windows Embedded Compact End-of-Life (EOL).
Run-time License: Windows Embedded Compact 2013 Entry (C13Entry)
Microsoft will provide this license until 31. May 2028. Toradex' customers are allowed to use and sell products running any of the below mentioned Windows Embedded Compact variant also after this date.
This license is backward compatible and therefore valid for:
Run-time License: Windows Embedded CE 6.0 Core
Customized Image / Additional Components
In case you build your own image form our BSP, and you use different components make sure they still fit in the pre-installed license. In case you use components not included in the pre-installed license you need to obtain the correct license form your local Microsoft Distributor.
